Question about Car Audio & Video
Airbag light won't go off - Car Audio & Video
  • 1 more comment
  • dbtexas Sep 08, 2008
    the problem with airbag light not going off. it's a 2004 honda civic. about a year ago it had a crash from the side but since than nothing just every day driving.
  • Anonymous Mar 16, 2009
    I got a '96 Honda Civic and the SRS Airbag light is on. I dont know if the car was owned and wrecked by the person I bought it from, but its on.
  • Jeremy Dellow
    Jeremy Dellow May 11, 2010
    What kind of car? What model year? Any work done on the car lately?
  • 1,586 Answers
Did you try turning it off using a scan tool (a shop would likely have to do that)? Or were you trying to turn it off by disconnecting the battery to reset the computer? Many faults can be cleared with a battery reset but an airbag light has to be turned off with a scan tool. The scan will also tell you which bag is tripping the failure, so you know where to look for a problem if the light won't turn off with a scan tool.
Posted on Oct 12, 2008
Airbag light
Unfortunately that will need to be checked out by your KIA dealership. The light indicates a malfunction with some part of the system. If you're under 80,000 miles it may be covered under warranty.
Jul 08, 2013 | Cars & Trucks
Airbag light won't light on dash
Usually if you pull the fuse the light will come on because the system is disabled. You may need to get the airbag module checked out.
Its fairly touchy stuff, you have to be careful not to blow the airbag by mistake when you are working on the system.
Jun 10, 2013 | 1995 Buick Century
Airbag
Yes, the airbag/restraint light is often triggered by a disconnected seat belt safety plug located under the driver's seat. Some people disconnect this plug so the vehicle will not chime the alarm while the seat belt is disconnected.
Apr 22, 2013 | Cars & Trucks
Airbag light won't stay off
airbag control module may need replacing
Apr 03, 2013 | 1999 Audi A4
Airbag light won't go off. On 2007 jeep wrangler x. Clock spring good sensor and computer all been recalibated for air bag
I'm not sure which airbag light is staying on the dashboard light near the speedo & tach, or the passenger airbag deactivation light near the 4-way hazard lights button slow the AC controls.
If it is the passenger seat disabled airbag indicator = look under the passenger seat and locate the wire/it going to your passenger seat. Disconnect/reconnect the plug and test it.
I have knocked mine ou, and caused the Disabled Airbag light to come on by shoving fire extinguishers, & First Aid kits under the seat and knocking it.
Jan 31, 2013 | Vehicle Parts & Accessories
The airbag light on our 97 bmw came on a couple days ago and won't go out
1st when the airbag light is on the system is disabled, so if u have an accident they will not work, as to the common cause read below.
When the airbag light is on it means a fault has occurred in the system and the airbag diagnostic monitor has disabled the system, the most common problem that turns the light on is a break in the connection to the steering wheel mounted airbag, this is due to a rotating ribbon contact that breaks under the steering wheel that connects the airbag to the wiring harness and the diagnostic monitor, the part is called th clock spring contact, a coiled up ribbon electrical contact that turns with the wheel
Oct 25, 2012 | 1997 BMW Z3 Roadster
My airbag light won't go off, what could be the problem?
If the warning light is staying on, there is a problem with the system and it is disabled.
You need to have someone scan the body computer to look for trouble codes.
Jul 27, 2012 | 1999 Audi A4
Why won't by airbag light turn off?
Usually the light is telling you there is a problem in the system and the system is disabled.
You may need to get the computer scanned for codes and go from there.
Jul 19, 2012 | 1997 Nissan Sentra
On my 1990 ltd cv air bag lights
Airbag lights are a bit more involved of a process. It could be as simple as getting your airbag control module reset (usually about $100-150) or it could be the result of a different problem. Possible causes for an airbag light are: 1) crash data stored in the airbag control module, requiring reset 2) bad clockspring - this sends data to the airbag inflator module 3) other fault in the SRS system. The only way to be sure what the problem may be is to get the system read for code and go from there. The airbag light will stay on regardless of a manual reset by removing the battery cable because the codes are stored in a different memory than standard trouble codes. Since the car checks the airbag system completely once you start, that is why the light won't go off until the data is erased from the airbag system control module. Once you find out what the cause is, getting the necessary parts and installing them would be simple enough. Do not just reset the system, have it scanned for possible codes first. Having an airbag randomly inflate while driving could prove to be problematic.
Jan 27, 2011 | 1990 Ford LTD Crown Victoria
Car Audio & Video Logo
621 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
