Question about Acer Aspire 3610 Notebook
My C drive full
The c drive is almost full 3.89gb left. The d drive is basically empty except for photos that I moved there. What else can I safely move to the d drive to free up space on the c drive? I have itunes with many music files.
  • am_m111 Sep 08, 2008
    I did but lost my playlists from itouch How do I get that back?
You could reinstall windows reformat hard drive and place both hard disks into 1 that's what i did
Posted on Sep 14, 2008
  • 689 Answers
You can move anything except system files and user settings. Before proceed further I suggest you to perform "Disk Clean Up" which is a simple application under accessories.
You can put iTunes files to the other drive. All documents and media files as well can be transferred and they will work without problem. Please post if you need further assistance
Good Luck
Posted on Sep 07, 2008
  • ExpressFiX
    ExpressFiX Sep 08, 2008
    You can recreate the playlist
1998 ford explorer fuel gauge stuck on empty-Not the typical suspects causing it?!?!?!
One of the wires to the sensor is touching a ground. It may be getting pinched
Mar 04, 2017 | 1998 Ford Explorer
Acer Aspire 5735, the C drive is full but the D drive is empty, can you change the partition so that more is given to the C drive?
Windows - You can't it is the active partition and contains the OS.
Use 3rd party software like Partition Magic. Be sure to backup first. This was not a safe thing to try.
Nov 11, 2012 | Acer Aspire 5735 Notebook
Hard drive c full hard drive d empty can i put them together or shift some from one to another
Well, the safest thing is to only move any photos and text docs to the D: So the 'My Documents' folder should be ok moved to the D: drive. I suggest you Google moving this folder to a different drive as you didn't specify your operating system and I only use XP.
Don't try and move any installed applications....these wont work again!
If you must move applications, (programs/software) then the only way is to firstly remove them in control-panel and reinstall them on the D: drive using your original install disks. Remember, by default programs get installed on the C: drive, so you have to 'tell' the install wizard you want it installed on the D: drive..
Hope this helps!
Apr 29, 2011 | Acer Aspire 1670
Will the cartidge box move if cartridges are empty?
For your information obviously the cartridges will move while you turn on the printer or give a print job if the cartridges are full or empty, but it will not print and will show a massage that "cartridge are empty" or "Ink level is too low". If there is any stuck on the way of movement then the cartridge will not move.
Apr 26, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
I have a sony vaio laptop with seemingly two internal hardrives but one is very full and the other virtually empty but i don't seem to be able to move stuff across to balance it? I keep getting a message...
you probably only have one hard drive ,it may have two primary partitions ,look closely at the d drive,even though the pie graph says is empty ,the physicall size in mb,kb,gb,could be small,so basically your moving things on your full "c" drive to a small partition on your full "c"drive labeled" d "drive,if this is not the case,go to controll panel/system/,device manager ,and observe hard disk properties,if you have two hard drives,you will see two hard drives listed,usually the cd-rom takes the "d" drive position,and an extra hard drive will be your"E"drive,but a single drive with two primary partitions,forces the cd-rom to be "e"drive,this configuration often causes problems with cd/dvd-rom drives,just a side note ,in case it applies to your situation,hope this helps,post a comment if you need more help,aloha from maui todd0708
Oct 06, 2009 | Computers & Internet
Sony Cybershot - the memory stick is full
More than likely the camera still thinks the photos are on the stick, especially if you deleted the images while it was hooked to the computer. I would safely move the rest of the photos off the stick onto your computer then format the card through the camera and with the camera disconnected from the computer. this should clear the card.
Feb 03, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Memoty full mesage
this happens quite abit with Samsung devices. Try to make sure you can move your pictures to your computer. Then, reformat your card.
  1. Insert a memory card into the microSD slot, located on the bottom left side of the handset
  2. From the standby screen, press the left soft key for Menu
  3. Select Fun & Apps (6)
  4. Select Files (1)
  5. Select Memory Card
  6. Press the left soft key for Options
  7. Select Memory Card Info (5)
  8. Press the left soft key for Format
  9. Press the left soft key to confirm Formatting the Memory Card
You can also reset the MMS option on your Samsung with this star/pound code:
Enter *2767*667#
E2P MMS Reset Is Displayed When successful
Feb 02, 2009 | Samsung U900 Soul Cellular Phone
Acer aspire 3610 with drive c(full) and drive d(empty)
Right click on My Documents and select Properties.
Select Move.
Navigate to your D: drive. Select the drive letter and then click "Make New Folder." Enter "My Documents" as the folder name and hit Enter and then OK. Windows will then ask you whether you want to move your documents. Click Yes.
All the space the My Documents folder was taking up on C: is now empty and you will notice no difference in the way you work. Anything that belongs in My Documents will now automatically go to My Documents on D:
Note: You may not want to do the next part if you need a lot of space for Pictures and Music.
To get even more space on C:, right click on My Computer and select Properties.
Click on the Advanced tab and then Settings in the Performance section.
In Performance Options click on the Advanced tab
In the Virtual Memory section click on Change
Select the D: drive and set it to be the same as the settings on C:
Now change the settings on C: to have a page file of 0
If you are someone who likes to keep old email on file, those files can also be moved.
Oct 12, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
146 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
