My Dad has the Panasonic SC-AK29 CD stereo system. The CD player has an intermittent playing problem. Some disc play fine, while others are reading as no disk. Any advice?
All this cd systems have the same problem. If you're using burned cd's sometimes they don't work so you need to close the session after burning in your burning program. If you're using original cd's it means that the device needs to be cleaned up (especially the lens) because the structure of a 5 cd combo device gets very dusty after a while. Also from my experience after cleaning it put a cd in each deck (even if it's off) so they could prevent it getting dustier again.
la bandeja de disco compacto entra y sale correctamente al inicio pero al cargar la superficie del...
(More)
la bandeja de disco compacto entra y sale correctamente al inicio pero al cargar la superficie del lector laser no sube y de igual forma afecta el cambio interno de una bandeja a otra, asi mismo ocurrida esta falla afecta todo el sistema de cd, en ocasiones el problema se supera. el laser lee correctamente los discos hasta los discos bien rayados. la falla original esta en la carga de la base del lector al iniciar la reproduccion del disco. que parte se puede reemplazar: es este el componente a reemplazar RD-DAC026-S CD LOADING MECHANISM ASSY o es otro distinto?
have had it for years may just be old but it started shuting off in the middle of play then one day...
(More)
have had it for years may just be old but it started shuting off in the middle of play then one day i turned it on and it read fgi or something like that and wont turn on. plus all my fav cds are in it
our Technics Cd changer sl- eh770 jumps while playing, we have used a cleaning disc but this does...
(More)
our Technics Cd changer sl- eh770 jumps while playing, we have used a cleaning disc but this does not have any effect.
