Question about Remington Electric Pole Saw
Chain tension The chain came off----how do I get it back on, and adjust the tension correctly?
  • Anonymous Nov 06, 2008
    Chain won't tighten up on mine and yeah, I know how to
    tighten it. Any suggestions on what might be wrong?
Hi Sally, I guess you don't have the owners manual. It tells you how to adjust chain tension. If you look around near the motor side of the bar, you should see two nuts that hold a bracket tight against the bar and an adjustment screw or bolt or something to loosen or tighten the chain by moving the bar or making it longer or shorter. Adjust that so that the bar is as short as possible and put the chain back in place. Then tighten that feature till the chain is snug again and tighten the two nuts to hold the bar firmly.
Posted on Sep 11, 2008
95 gpz chain tighten how to
hey Dominico,
This is the way PROFESSIONAL mechanics do a chain/sprocket check and drive chain alignment and tension.. Proper chain tension is very important to the life of your chain and sprockets and performance of your bike. First, you need to check to see if the chain/sprockets need replacing. (Chain and sprockets are ALWAYS replaced as a set (-all-3)..if you replace a chain on worn sprockets.. the chain will stretch out QUICK.. and if you put new sprockets with a worn chain.. the sprockets will be worn out QUICK too!!) ...To do this..the bike needs to be on the center stand or bike stand...NOT on the side stand...
...now...--remove the chain guard-- next..Sprocket check time - take one hand and squeeze the chain (grab the chain above and below the swingarm) at the point between the axle and the swingarm bolt.. as hard as possible. to take all the slack out of the chain and put the tension completely around the back sprocket.. while you are squeezing the chain as hard and tight as possible.. - with your other hand - try to lift/pull the chain off the rear sprocket.. IF you can pull the chain off enough to see if there is a .200" or 5mm max. gap between the chain and sprocket - under the chain... or MORE THAN A HALF a tooth groove under the chain..or the chain pulls up more than two teeth...OR the teeth on either sprocket are "pointed thin" or rounded inside....you need to replace the chain/sprockets.
...ONCE you are sure the chain/sprockets are good..its time to CORRECTLY align and adjust the chain tension. Loosen the axle nut.. DO NOT remove it.. now - tap it gently to make sure its loose...loose the chain adjuster nuts.. back them off a good bit, but do not remove them...you may,also need to loose the rear brake caliper mounts ..you should be able to move the rear wheel forward and backward with your hand.(this is to assure you have sufficient "looseness" to make the proper adjustment...NOW - pull the rear tire backwards until it stops.. - run the adjuster nut(s) until they are just snug..ALIGNMENT - This is CRITICAL - (did you remove the chain guard yet?) - do that now. You must be able to see down the entire length of the chain (above the swingarm)..The chain MUST RUN IN A STRAIGHT LINE!! .. The little marks on the swingarm are just "guides".. never use them as perfect.. the only way to assure CORRECT ALIGNMENT is a visual check of the chain to make sure its in a straight line!!!! - ...ANY bend, crook, or mis-alignment will cause premature wear and tear, and make it harder for your engine to make it turn. - Now - Rotate the wheel and find the tightest point of the chain... there is one, and its normal... LEAVE the tight point located between the two sprockets on the top of the swingarm. This is where you will "feel" for the correct tension.
The biggest thing most people miss when adjusting the tension is having the AXEL/NUT and the SWINGARM PIVOT SHAFT and the COUNTERSHAFT C/L (front sprocket shaft) IN A STRAIGHT LINE - ALL THREE ARE ON THE SAME PLANE!!!!!
. NOW, You may have to get a buddy to help pull the swing arm up.. (I use a tie down strap through the rear wheel and over the seat pulled tight enough to make AND KEEP the STRAIGHT LINE!!)
..Once you have established the straight line - --- - --- - and MADE SURE the chain is RUNNING STRAIGHT on both sprockets.. NOW _ its time to adjust the tension. There WILL be a tightest and loosest point of the chain..(normal).. you MUST adjust the tension using the TIGHTEST point of the chain....set the tension so you can move the chain up and down (total movement) about 1 3/8 inch to a max of 2 inches!! Once you have established the chain is straight and the tension is correct, its time to TIGHTEN EVERYTHING in order... start with snugging the axle nut.. then snug the adjuster nuts more..-- DOUBLE CHECK you chain alignment.. now - tighten the axle - TIGHT!!... tighten the adjuster nuts..lock down the lock nuts.. tighten the caliper.. TRIPLE CHECK the alignment... double check the tension...double check all the nuts... install the chain guard... REMOVE whatever you use the keep the straight line straight..
TRIPLE CHECK ALL NUTS!!! NOW ROTATE THE REAR WHEEL AND CHECK FOR BINDING AND MAKE SURE THE CHAIN IS WORKING CORRECTLY AND NOT TOO LOOSE..
KNOW you have done a job correctly!! (I am a factory trained mechanic, race engine builder, port work guy, race tuner.)..
GREAT JOB!!
Aug 08, 2017 | Motorcycles
Tip
StarTrac NXT Chain Tensioning & Alignment Video
About This Video
Adjusting Chain Tension and Alignment on a StarTrac NXT
  • In this video, we show how to tension and align the chain and flywheel on a StarTrac NXT bike
  • First you see an example of a chain that is way too loose
  • To correct this loosen the flywheel bolt on both sides of the flywheel
  • Loosen the tension nut on the sprocket side of the bike and tighten the tension bolt until you get the proper deflection on the chain
    • A properly tensioned chain will have roughly 3/16" of deflection
  • Tighten the tension nut and the flywheel nut on both sides as shown in the video
Check the Alignment of the Chain and Sprockets after Making a Chain Tension Adjustment
  • Misaligned chains will look like they are walking from side to side where they enter and leave the sprockets
    • This can cause noise, premature wear, as well as making the chain look to be jumping from side to side during use
  • To correct this, loosen the flywheel nut on both sides of the flywheel, then loosen the tension nut and adjust the tension bolt to move the flywheel in the proper direction needed to align the chain with the flywheel sprocket, as seen in the video
    • Note: If you have already achieved proper tension of the chain, adjusting the tension nut on the opposite side from the sprocket will help to keep the same tension on the chain
  • Don't forget to check the chain tension after making an alignment adjustment
Chain Tensioning Alignment Video for StarTrac NXT Bike
on Feb 11, 2015 | Startrac Fitness Products Star Trac 4410HR...
Husqvarna 50 chain keeps coming off
Are you adjusting the chain tension correctly?? Make sure the bar in installed correctly with the tension adjustment pin in the appropriate hole. Elevate the tip of the guide bar while adjusting the chain adjustment screw until the chain is snug but not tight. Then tighten the bar bolts without lowering the tip of the bar. Also ensure the drive links are engaging the sprocket correctly.
If the chain is adjusted correctly and the problem still exists, remove the sprocket side cover, bar and chain and inspect the sprocket for extreme wear. Once the sprocket is worn excessively it won't want to engage the drive links of the chain correctly which could be the source of the problem. If so, replace both the sprocket and the chain because the excess wear of the sprocket could have damaged the drive links of the chain and putting an old worn chain back on with a new sprocket will cause the new sprocket to begin wearing prematurely.
Apr 12, 2015 | Husqvarna Garden
I tightened my chain on my 04 r6 and after I tightened everything back up I can barey roll it in neutral when I'm sitting on it. Can you over tighten the rear axle nut?
YES, and you set the chain tension with - Countershaft sprocket centerline, the swingarm bolt centerline, and the rear axle nut centerline - ALL THREE IN A STRAIGHT LINE....Use a yardstick to make sure they are IN LINE!!! Have one of your fat buddies sit on it while you adjust the chain. Make sure the chain runs IN A STRAIGHT LINE regardless of the marks on the chain tensioners!!!!!!!! I have always loosened the chain a lot, kicking the tire forward so when I CORRECTLY adjust the chain it is MUCH EASIER to make sure the chain is in straight line (you should remove the chain guard so you can see the chain), do it slowly, rotating the tire while watching the chain, making sure IT RUNS TRUE!! - Forget the alignment marks!!... then slowly get the tension correct (with your fat buddy sitting on it).. remember what 3 things HAVE to be in a straight line... snug the tensioners good - NOW tighten the axle...do not over tighten. THEN finish snugging down the chain tensioners. reinstall the chain guard. Double check the axle nut!!!!
Chain tension done professionally!!!
Jul 25, 2014 | Motorcycles
Chain keeps poppin off
These are the instructions for adjusting the chain. They are taken directly from the manual available at http://ep.yimg.com/ty/cdn/razorama/e100e200e300manual.pdf
To adjust the chain:
1. Loosen the axle
2. Loosen the brake anchor (this is attached with the small bolt in the long slot on the left side of the rear fork)
3. Tighten the tension adjusters on the axle 1/8 to 1/4 turn to tension the chain. Tighten both adjusters the exact same amount to maintain the wheel alignment.
Note: this system of adjusters is common to motorcycles and BMX
bicycles so I your are not familiar with it, if you know anyone who is,
they would not have a problem adjusting it for you.
Chain tension: The chain should be "just not-quite snug" in other
words, not taut or sloppy loose. BE CAREFUL NOT TO ADJUST TOO TIGHT. The tensioning system can easily impart too much tension and snap the chain or bend the motor output shaft. Turn the adjusters 1/8 to 1/4 turn at a time and recheck the tension each time.
4. Once the tension is good, tighten the axle and brake anchor bolt. Test run the scooter. Readjust as needed.
Jan 02, 2014 | Razor E100 Electric Scooter
I have removed my rear wheel from a DMR reptoid, to fix a flat, and have assembled it back togather but not sure if i have tightened the chain tensioner correctly. Is there a correct procedure for...
Use a search engine for "adjust bicycle the chain tensioner". Common questions, especially regarding mechanical things we can't see, should be filtered through search engine first.
Aug 07, 2011 | DMR Reptoid
How do i put a chain back on a chainsaw?
Locate the bolts on the bar, down close to the engine. Loosen them. locate the chain tensioning adjustment, again, close to the engine, but on the other side. Loosen it also. Place your chain on the bar and on the sprocket. Tighten the bolts enough to take the slack out of the bar, but not so much that you cannot use the adjustment tensioning screw. Tighten up on the tension adjustment until the tension on the chain is right, and then tighten the bolts.
Best regards, --W/D--
Please feel free to rate this solution. Thanks
Jan 31, 2011 | Garden
I cannot find my manual to my 18v cordless chainsaw ccs818. I need directions for putting the chain back on. I would like to download a copy of the manual.
Your manual can be found here:
http://www.blackanddecker.com/Manuals.aspx with pop-ups enabled then enter your model number
or
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90560838,CCS818.pdf
See the instructions for replacing the chain on page 11. It makes reference to the figures on page 6 so that you know exactly what to remove.
Basically... loosen the bar allen screws. Remove the sprocket cover. Loosen the bar retaining bolts. Use a flat bladed screwdriver on the bar / chain tension screw to shorten the bar enough to install the chain. Then adjust the chain tensioner so that there is just a little slack in the chain at the bottom of bar between the drive sprocket and the bar. Tighten the bar retaining bolts install the cover / tighten all cover fasteners. (see details D and E page 6 of the 2nd link above.)
The steps below are copied from the manual.... I can not undo the formatting and can not post the figures here due to size restrictions..
Thanks for choosing FixYa,
Kelly
Replacing the Saw Chain
CAUTION: Sharp chain. Always wear protective gloves when
handling the chain. The chain is sharp and can cut you when it is
not running.
WARNING: Sharp moving chain. To prevent accidental
operation, insure that battery is disconnected from the tool
before performing the following operations. Failure to do this
could result in serious personal injury.
• Place the saw on a firm surface. Rotate the two allen head screws
(11) counterclockwise with the wrench (13) provided as shown in
figure E.
• To remove the saw chain (9), rotate the tension adjustment screw
(23) in the front of the housing using the flat screwdriver end of the
wrench (13) as shown in figure F. Turning the screw
counterclockwise allows the guide bar to recede and reduces the
tension on the chain so that it may be removed.
• Remove sprocket cover (10) and allen head screws (11).
• Lift the worn saw chain (9) out of the groove in the guide bar (8).
• Place new chain in groove of guide bar making sure saw teeth are
facing correct direction by matching arrow on chain with graphic on
housing shown in figure G.
• Place the saw chain and guide bar assembly around the sprocket
(19). Check to make sure that the slot (20) in the guide bar (8) is
over the two location pins (21) shown in figure E and that the hole
below the slot is located over the adjustment pin (22).
• Replace sprocket cover (10) and thread allen head screws (11) in
with wrench until snug, then back wrench off one full turn.
• Pull bar nose up and keep it up as you adjust tension.
• Rotate the tension adjustment screw (23) in the front of the housing
clockwise to increase the chain tension as in Figure F.
Follow instructions in "Adjusting Chain Tension" section.
• While still holding the bar nose up, securely tighten the rear allen
screw (11) first, then tighten the front allen screw.
• When the chain is new check the tension frequently (after
disconnecting battery) during the first 2 hours of use as a new chain
stretches slightly.
not running.
• With the saw still on a firm surface check the chain tension. The
tension is correct when the chain snaps back after being pulled
1/8 inch (3mm) away from the guide bar (8) with light force from the
middle finger and thumb as shown in figure H. There should be no
"sag" between the guide bar and the chain on the underside as
shown in figure I.
• To adjust saw chain tension, loosen the allen head screws (11).
using the flat screwdriver end of the wrench (13) as shown in
figure F.
• Do not over-tension the chain as this will lead to excessive wear
and will reduce the life of the bar and chain. Overtensioning also
reduces the amount of cuts you will get per battery charge.
• Once chain tension is correct, tighten allen head screws (11).
stretches slightly.
Nov 08, 2010 | Black & Decker Garden
POULAN CHAIN SAW MODEL 1420 ''Chain came off track
Chain is probably stretched. SAFETY FIRST. Electric saw, make sure power is unplugged. Gas saw, make sure sparkplug wire is removed. Remove the cover where the bar is attached to the saw. U should see an adjustment screw for chain tension and one or more bar lockdown screws. Loosen the lockdown screws and turn the tension adjustment screw to permit the bar to slide back toward the motor. Put the chain back in the bar track all the way around. Adjust the tension screw to tighten chain enough you can't pull it out of the track at any spot. Slide the chain by hand at least one complete revolution feeling for any rough spots. If it moves freely, turn the tension screw enough to tighten the chain properly. Correct tension should allow you to pull the chain appx. 1/16 to 1/8 inch from the bar. Tighten the lockdown screws, replace the cover. Rotate chain by hand a couple of revolutions again to check for smoothness again before starting the saw.
Jun 26, 2009 | Poulan 952801953 Electric Chain Saw
Remington Electric Pole Saw Logo
340 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
