Power outage computer will not start no POST, no nothing has "that smell" though
  • maxinejudi Mar 28, 2009
    Orange LED light on--power cords all secure-front button wont turn computer on
Someone please help!!!
does any one knows what to do when a Dell Dimension 3100 won't start-up. After a major power outage my PC does not want to start.
Posted on Feb 11, 2010
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
Well we had a power outage today and when the power came back the computer went back on but instead of starting up windows the blue power button flashes. but the fans and components inside the computer...
if there is no post sound (beeps) and the pc does have a speaker you can try this first.
remove the power cable
hold the power button in for 15 seconds to clear the residual power.
replace cord and power on
if you still have the same result, then you need to learn how to reset the bios/cmos on your system.
Jun 27, 2011 | Computers & Internet
I use a Belkin Surge Protector UPS 600VA, and run Win 7 64 bits. In "System Configuration", "Services" tab, Belkin APmonitor is stopped, and Belkin APMRMI is running. Nothing shows on...
2 scenarios will either play out at the end of the day:
1. During power outage, your UPS will continue to supply backup power for the number of minutes.it is built/designed to do for your PC after which it shuts down and your PC due to lack of power shuts down too.
2. if you've programmed your PC to shut down after say a short period it idles, your PC will shut down even though your UPS is still fully operational.
A third approach is to sync the situation/scenario you envisage by powering off your UPS power supply at the mains/wall receptacle.
Watch what happens next by leaving your PC idle but still connected to the UPS still powered on (but without the mains power supply to it)
Oct 06, 2017 | Computers & Internet
After a power outage my dishwasher has a "Er" code. I downloaded the manual and it says nothing about that specific code. Please help! "Er" code GE Profile Dishwasher GSD4930X66WW
the er means error. you may have a damaged control from the power outage. try to turn the power off to the unit for 30 min then put it back on. see if it resets it.
Jan 10, 2011 | GE Dishwashers
Netgear wireless router has no lights after power outage. Actually, the circuit breaker switch for the room the router is in, was accidentally flipped. The power light will not even come on. The device has...
On the router, you will see some sort of ventilation for the air to pass try smelling from there and if you smell anything the smells like burnt plastic or rubber then the device itself is burned from inside because of the power outage, however, this is extremely rare case scenario I doubt it will burn like that so easily, and do perform the same step on the power source adapter of the router because in many cases it is the power source that gets burn and not the device.
After that perform some troubleshooting steps check if the power chord connected to the router is properly connected also please check the power outlet with other electronic devices to see if the outlet is working.
I am not sure but I am assuming that it is the power adapter that got damage and not the router. Let me know if any issues.
Aug 27, 2017 | NetGear RangeMax NEXT WNR834B Wireless...
My computer will not turn on
many, not all, psu's will internally tripo after this happens. how to reset:
1 if it has an on/off button turn off for 1 min and turn on.
2 if it has no button but has a 110/220 switch, unplug it then switch to 220 then back to 110 (also this may be 115/230 or even 120/240)
3 if it has neither of these, unplug it for 10 mins, then replug it and start up.
also when you opened the case did you smell anything funny? if so i would say that the mobo and/or cpu are done for. i doubt this tho because you had them on a surge, but it is possible.
1 more thing when you opened the case did you by chance knock a wire loose from the mobo?(motherboard)
after re reading your post i question whether the surge strip is good, because you said it was tripped and yet you had the posu light on. or did you mean a light inside the case of the computer itself?
if none of these suggestions help you please re post with answers to the questions i asked thanx and hope i have helped.
Jun 08, 2010 | Hi-Pro PSU HIPRO|HP-E3509 300W OEM...
We had a power outage - the computer was on a circuit breaker outlet. The other computer came back on, but the one with the siverstone power supply will not start up
Hmmm, First of all check the fuses if any that may have burned out due to the power outage. If this doesnt help. Open up the power supply and smell it for any burned out parts. If you can smell the scent of burned electrical parts then you should replace the power supply. It should solve your problem. Also check the motherboard for any anomalies.
May 19, 2010 | Silverstone SST-ST60F (SSTST60F) 600-Watt...
We had a brief power outage--now prinker knunks
In all probability that Power Outage caused a massive Spike or Surge on your power line. This has affected this unit. It doesn't take much to cause this type of thing and is quite common. It may be repairable, however these days buying a new one is often a better option. If you do go the repair route, go to a reputable place, & please ensure you get a firm "Quote" not an "Estimate" for repair.
Jan 20, 2010 | HP Photosmart 2410 All-In-One InkJet...
Cpu not starting after power outage
need new power suplly that one got shot and make sure your on hi end protecter never on wall ok
Jan 30, 2008 | Computers & Internet
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
