Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Bravo 13 in 1 tv remote control
By patch_casaru on Sep 07, 2008
hi
can you help i have a tv JVC MODEL AV-24WT2EK and have a bravo 13 in 1 remote and need the code to put in so it will operate my tv. cheers r kelly
Best Solution
posted on Oct 06, 2008
Very Helpful)
testimonial
Rank: Apprentice
Rating: 100%, 3 votes
Greetings and blessings,
I am trying to use the Bravo 13 in 1 remote control on Toshiba tv to set up my BT Vision. I cannot do this because I do not hav ethe manual for the Bravo to enter the code.
Can you Hlep me please?
Thank you.
Chris
Blessings
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 18, 2008
Somewhat Helpful)
shooterfan
Rank: Apprentice
Rating: 75%, 4 votes
User Instructions for _
Universal Remote Control.
This is a multifunctional unit with the
following features:-
*Operates up to 12 devices.
TV 1/TV2/VCR1/VCR2/
Satellite TV/Cable TV/VCD/DVD
/CD/HiFi/AUX/Amplifier.
*Operation modes (4) are:— Set-up
mode, Quick search mode,
Auto search mode, Display mode.
*LED indicator For transmission and
set—up.
Setting Up. .
lf you are setting up an AVdevice
please make sure there is a tape
or disk inserted.
1-Look in the BRAND CODE LIST to
find the 3 digit code for
device, brand name, and model.
*Press and hold the [SET] key, then
press the device key eg.
[TVi] [VCR] [SAT] ctc.
•When the LED indicator lights up
release both keys.
Input the 3 digit code for the device.
The LED indicator will
go off if the code number is correct. lf
the code is incorrect the
LED will flash twice and remain in the
set-up mode. Input another
code from the BRAND CODE LIST.
*lf at any time you want to leave the
set-up mode, press the device key.
The system will come out of the
Set-up mode after ID seconds if no
other key is pressed.
Display Mode
To display the CONTROL CODE for a
device.
•Press and holdthe [SET] key and
press the digit you want to display
( 1,2 or 3)
*ReIease the[SET] key.
*Count the number of times the LED
indicator flashes. The number of times
the LED flashes is the digit number. lf
the LED does not flash then the digit
number is zero.
Additional Information.
When changing batteries do not press
any keys.
Quick Search
Ii you are unable to find the correct
code for your device in the
BRAND CODE LIST, then you can
use this procedure to search
automatically for a code.
•Press and hold down the [SET] key,
press the device key [TV/VCR/etc.]
The LED indicator w ill be on. Release
the pressed keys. Press the [SET] key
again and telease it.The unit is now in
Quick search mode, and the LED will
keep flashing.
*The direction of searching can be
changed by pressing the [SET] key.
*Point the control unit at the device
you are setting up and prcss the
[POWER] key.
If the selected device operates. check
the rest ofthe functions such as [VOL],
[CH+/-]. lf the device cannot he
controlled repeat the instructions in
this paragraph.
*To change the direction of search,
press the [SET] key.
•To leave the search mode press the
device key and the LED indicator will
go off.
Auto Search
*Power on the device to be controlled.
- If it is a VCR a tape must be inserted.
*Press and hold [SET] key. Press and
hold [POWER] key for more than 3
seconds, and the Auto Search will
begin.
Press any key to exit.
Comments:
Dec 18, 2008
- Which button on the remote changes the av channel? (i.e. to select scart etc)
For a Watson FA2801TS tv I found a code is 081 but it seems to be limited to the power button,changing channels and volume...
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
I need a code number and programming instructions for a Gemini Easy 3 Remote. The TV brand is... (More)
Answer
I have purchased a swiisstec 15'' LCD but the remote doesn't work, I think the wrong remote is in... (More)
Answer
just got brand new coby 22' screen and don't have code to program direct tv remote control
Describe your Remote Controls problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote Control Experts
Top Audio & Video Equipment Repairmen
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
