Question about Philips Magnavox 51MP392H Rear Projection Television
We have a magnavok big screen tv
The auto lock is on the tv and it needs a code is there any way i can reset it or get a code
    Scholar:
  • 33 Answers
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Posted on Nov 20, 2008
I have a mitsubishi big screen tv that locked up on me. How do i figure out the code?
A model number and a better description would help answer this problem.
Most Mitsubishi sets have a hidden OPTION menu that will allow a hard reset of the entire set but should only be used with certain issues.
Apr 15, 2012 | Mitsubishi Televison & Video
Hitachi 46w 500 screen says locked
reset the tv by pressing the reset button.
Aug 21, 2008 | Televison & Video
My tv is locked and asking for a an unlock code. I have never had a lock code on the tv since i bought it several years ago. How can I reset or bypass this feature. BTW mt TV is a 48-50" projection...
Hello
I thinks that you have its original remote handset with you now, and posts this solution. If you don't have it, either buy a new original remote handset or try to get it from any of your friends and relatives, who owns the same model of Mitsubishi Tv, you have now; only to unlock it. After unlock, you can use any other remote control.
Mitsubishi sets use a four-digit code for a V-Chip locked program, view a locked TV, cancel the lock, or to enter the V-Chip lock menus. You can view the locked shows on the TV set by pressing the number 9 and QV buttons on the remote at the same time, whenever your code is requested. This process temporarily unlocks the TV and asks you to enter a new code.
OK.
Sep 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Need tv code, tv is locked
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
5
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Also note that forgotten the passcode of your Mitsubishi TV. You can make it alive without knowing the passcode. Please follow
V_Chip lock bypassing prodedure is as follows
You can view your locked TV, cancel the lock, or enter the V_chip lock menus.
This is done by pressing the number "9" and "QV" buttons on the remote TV control at the same time, when your passcode is requested. This process temporarily unlocks the TV.
When entering the V_Chip lock menu, this process deletes your old passcode and prompts you to enter a new passcode.
I hope this will help to solve the problem...
Aug 20, 2011 | Mitsubishi VS-60703 60" Rear Projection...
No Auto tune
You try to unlocked all child lock after that on replace Main board or part call tuner in main board
Jan 21, 2010 | Televison & Video
How to reset personal identifaction code (PIC), for mitsubishi 42 inch big screen tv, model #VS4503R. Input is locked until the PIC is entered
Did you do a hard reset? (Just unplug the power cord for 4 hours, then try again. It may help; I will give it a 50/50 chance).
If the reset does not help, go into the osd and reset all the feature/parameters that relate in any way to zoom and see if that will relieve it. Even the caption setting should be checked for correct function.
If the reset and the OSD check does not help, you will need service. It is probably the controller IC (this is one that regulates the overall operation of the set). The zoom is needed in order to change the picture aspect ratio for 16/9 hd as well as regular square tv.
Oct 11, 2009 | Televison & Video
TV is lock
Using the Mitsubishi remote, go to the locked function and when it asks for the code pres QV and 9 at the same time on the remote, this will work in any mode which may be locked, including entering a new password!
Jan 04, 2009 | Mitsubishi VS-60703 60" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Need manual/code book for oneforall.com remote for toschiba tv
hi having a problem.getting ther code for a sharp lcd projector.model pg-c20x.have one for all urc-7740.tried all the codes and search methods.no joy.
May 21, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Help
Good Day, jake1;
This TV is not known for this problem, but when TV has blue screen, it normally means the TV is lacking a signal. Ensure you have that.
Do you get OSD, on screen display? Try different inputs such as DVD. What happens?
Let me know, big IRISH.
Mar 18, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
275 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
