While connected on the internet (wireless) if we leave the computer idle for few minutes without touching anything it disconnects, and takes some time before we can reconnect again. The screen saver is not set. What could cause the linksys USB to disconnect when not in use? I have to unplug and replug the USB to get it working again.
It could be a time-out setting that is on the router or a setting inside the computer. It could also be malware that has gotten in and affected certain settings that mess with the internet. Have you noticed any weird things going on with the computer lately?
Posted on Sep 07, 2008
Do i need to relearn the tps on a 1999 vw jetta
Unhook battery, press brakes to de-power everything. Leave unhooked for half hour or more.
Re-connect the battery. Turn key to on position. Do not start the car... just to on. Don't touch the gas pedal at all. Leave for ~10-20min.
Turn key straight to start and start the car. Do not touch the gas pedal. Let idle for ~10min without touching anything.
Turn off car. Restart, drive. It might take a few heat cycles and a bit of driving before the ECU 'learns' everything over again.
Jul 10, 2015 | Cars & Trucks
Disconnecting dap 2360
Your wireless network card in your computer is failing, or the cable to the computer is bad. Because you said wireless internet, I am going to assume that you are connected to the internet via wireless nic. If your pc hasn't been rebooted for a while you may want to try a reboot and see if that doesn't fix the issue.
However, if the problem remains you will likely need to get another wireless network card.
Nov 23, 2013 | D-Link Computers & Internet
Disconnecting in a few minutes
Change your position , that might help the signal to be better, wireless signal gets obstructed
Nov 23, 2013 | D-Link Dap-2310 Wireless Access Point
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
Replaced ink cartridge still not working
Please remove all the cartridges, clean the Contact points on the cartridges and on the Printer with alcohol/spirit/acetone using a soft brush, don't touch the print heads, you may damage them.
Turn off the printer, disconnect usb cable, power cord and ethernet cable (if any). Leave it Off for few minutes (fix minutes will be enough), also remove/disconnect the power cord from the mains.
Do some cleaning if you can.
Now press the power button several times. Connect the power cord and power on the Machine without anything installed/connected, again leave it On for few minutes and turn it off.
Connect the usb cable and ethernet cable, Switch on the printer and install the cartridges. If there's no internal problem this will definitely fix your problem.
Good luck.
Thanks for using FixYa.
Jun 30, 2010 | HP Officejet H470 InkJet Printer
Why does my Belkin N wireless router disconnect and reconnects
Turn off the firewall in the Router
Step 1 : Open RSP By typing 192.168.2.1 on the address bar of internet explorer
Step 2 :On the left side click Firewall
Step 3 : Leave the password blank and click submit
Step 4 : Disable it and click Apply
Step 5 : Restart te Router And try a Skype call
Step 6 : If it works let me know at warrierrakesh@ymail.com
Jan 04, 2010 | Belkin Wireless-N Wireless Router with...
D-Link DIR 655 - DHCP server but no internet
This usually happens when the router has timed out trying to grab an IP address from your modem.
I suggest unplugging your router and modem, waiting 1 minute, plugging in your modem, wait 1 minute, plug in your router, wait 1 minute, then try to connect again.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | D-Link DIR-655 Wireless Router
Wifi Router automatically disconnects from Internet.
It could be your router settings; OR it could be your ISP if your leave it 'idle' for very long.
Aug 12, 2009 | D-Link DIR-615 Wireless Router
Adapter no longer detecting ANY connections.
Hi cpjango,
Most routers especially the smaller ones do not have anything that resembles good ventilation.If you touch the router and its anything more than luke warn then its pretty clear that your router is overheating and unless you take a few steps could be at risk of being damaged beyond repair. My suggestion is to make sure its standing in a position where minimal router surface touches anything else.Also keep it away from your monitor, pc, desktop and anything else that produces heat. If it keeps randomly shutting off i would even recommend a small fan or a replacement.
that said I am assuming its not your service provider.
please tell me how this turns out.
Nov 13, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
Must boot 2 times to reach internet.
Just a thought...got to Start->Control Panel->Power Options
What are the settings? Is anything shutting down after a short period of time?
When it's disconnected, can you manually reconnect? Have you tried that before rebooting?
What kind of router are you using, have you modified it's settings in any way? I have some other thoughts, but maybe you shoudl answer these questions first.
Dec 19, 2007 | HP Pavilion dv1310 Notebook
Computers & Internet Logo
David Payne
David Payne
