Question about HP OfficeJet 7310 All-In-One InkJet Printer
Will not print color
Worked fine yesterday, turned it on this morning and will only print black
replaced color cartridge, no help
Later it would not print at all.
I replaced the printer with a new one
Posted on Sep 08, 2008
HP Officejet 6500 Will not print black. All ink if full, even replaced the black cartridge with new. Clean heads (via utility) 3 times. All other color cartridges (c,m,y) are printing. Work fine...
two actions I took that worked.
1) Remove the print cartridges. Raise the lever that holds the printer casing down (plastic square box), lift it up gently, remove it, and wipe with a clean, dry paper towel.
2) from the menu option on the printer. Go through the set up option and select "clean printer head" from the options. It will also do a self clean.
I did those two and it works nice.
Feb 08, 2011 | HP Officejet 6500 Wireless All-in-One...
Have changed the black ink in the printer as it was displaying error code 4. It is now displaying error code 5! What does this mean. What should I do?
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I bought a refilled black ink cartridge for my
Replace color cartridge.Printer can't print without color cartridge.In your case the color cartridge is failed.
Nov 24, 2009 | Canon PIXMA iP1600 Printer
Black ink wont print, but color works fine
The black cartridge needs replacing it sounds like. On many printers, that is the only way that you get black.
Jul 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
Hp psc 1510 prints reddish-pink color
the photo come out pink and i buy yesterday can you help me hp 1510
Oct 30, 2008 | HP PSC 1510 All-In-One InkJet Printer
Epson stylus photo RX500
Turn the printer off overnight and try the head cleaning process again. Leaving it unpowered for an extended period softens the ink and makes the cleaning more effective. It may require several cleaning cycles.
Apr 05, 2008 | Epson Stylus RX500 All-In-One InkJet...
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
47 people viewed this question
Seeker5211
Seeker5211
