Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Hoover dt999 dishwasher makes loud pop/bang around 30mins usually from end of cycle and smells of electrical burning. Thanks Graham
  • 93 Answers
Check the ellement the ellement is normally used at the end of rinse foe sanitising the dish maybe shorting out at the connection below remove bottom pane obsrv it ewhen in the area where it happens to see if no drips fall on the conection or short a t te connecters of the ellement thanks from gilles
Posted on Mar 15, 2009
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
What does E4 mean on a Hoover DT999
Hi well check the following 1.discharge hose is not bent. 2.Filters are not blocked. 3.Syphon is not blocked
Thanks! mannu_rakesh
Aug 13, 2009 | Hoover 24 in. DT999 Free-Standing...
Loud bang, smell of burning
hello sir,
there must be a electric short circuit happened in ur machine, plz check all d wires, b4 replacig the blown fuse.
or else u must have connected ur machine to a wrong rated power terminal.
plz isolate ur body from the machine while fixiing this problem, n ensure that there is no leakage of current after u fix it.
thank u!!
if my solution is currect then plz vote me sir
Jul 18, 2009 | Hoover Dryers
Blows fuze and has burnt electrical smell
Time for a new dishwasher. Had the same problem. Tech came out and threw hundreds at it cause it was under warranty at the time, i didnt pay a dime and ended up buying new one.
Jun 04, 2009 | Fisher Dishwashers
On one minute then POP loud noise, burning smell
Loud popping and loss of power is common on plasma TVs and is usually either the Y sustain or Z sustain boards or buffers; in these instances the damaged part will be quite evident.
If this is an LCD you might have degraded insulation on one of the pink/blue backlight power leads causing high voltage to 'arc' to the chassis.
The loud bang and smell is actually to your advantage as in these circumstances the damaged part is usually evident. It'll just be a matter of popping the back off and sleuthing around. :)
May 18, 2009 | Sylvania Televison & Video
Our Hoover HD98E Dishwasher stopped working properly today. After a while the machine stops during the power spray cycle and just buzzes as though the pump is powered but not spraying. Is this the pressure...
its possible that your timer has a bad contack at this spot the machine stops but the drain valves open try advancing the timer one notch to see if it will work if yes relace the timer thanks from gilles
Mar 14, 2009 | Hoover 24 in. DT999 Free-Standing...
I have a hoover performa 1100 and twice this year (2nd time last night, 1st time 2 months ago), it has exploded with a loud bang followed by a burning/singed smell and smoke. It is 8 years old. It has...
mains filter capacitor usually goes with a bang and puff of smoke it is usually located near to where the mains cable enters the machine fixed to the rear panel by a nut the main cable is connected directly to it then the cables from it feed power to the machine. the capacitor is usually round in shape and has four connections onto it
Jul 19, 2008 | Hoover Washing Machines
Hoover dt999
E4 means that water is not discharging properly, check the hose, filters etc
Mar 30, 2008 | Hoover 24 in. DT999 Free-Standing...
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Noisey dishwasher
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes; check your owner's manual for proper loading methods. Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior; be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them. Be sure your dishwasher is sitting level. Adjust the feet beneath the unit by screwing them up or down. If there are lock nuts on the feet, make sure they are tight. A thumping or chattering sound during the filling cycle usually indicates that the inlet valve needs to be replaced. Unless you're handy with this sort of repair, this is a job for a repairperson.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
255 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
