HP OfficeJet 6110 All-In-One InkJet Printer
Problem for HP OfficeJet 6110 All-In-One InkJet Printer
"Clear carriage jam" persistent error...
By dot com on Feb 08, 2006
Greetings. We're trying to service a client's similar model. After disassembling it, we found a worn composite gear located at the ink cartrigde cleaner moving plattform (located at the front right corner of the product; it has 2 rubber cushions inside that protects the cartridge's nozzles), and a little "L" shaped plastic piece with a hooked end, located near the paper out tray (we suppose it's used in pair with a similar one for pushing the printed paper out in its tray). We substituted the gear, glued back the plastic hooked piece, and reconnect all wire harnesses, leaving clear the sides of the equipment to see it working. We observed the motor assy. located at the cartrigde cleaner unit overturning and causing the rubber cushions plattform to get stuck (therefore causing gear damage). Then, because of this failure, the cartridge carriage returned violenty to the left corner, causing breaking of the little plastic hooks (they get out during the equipment startup, but only after the cartridge carriage returns to the right corner). To isolate the problem, we removed the ribbon cable of the cleaner box motor during startup; that eliminated the violent carriage left return, but the error still flashes on the product's LCD. We have concluded the main board (PWB), Q1636-20261A, is the culprit. Can anyone agree with us, or have another view to the right solution? Thanks in advance.
Same Problem
Mar 11, 2009
-   i hav been using my HP inkjet 5610 all-in-one printer normally and just recently it started giving me problems. I have just installed my cartriges and been printing a few paper works and now all of a sudden it says ''Cartrige Jam'', so i don't know what could be the problem with it.-   Guest
Feb 01, 2009
-   **** -   Guest
Jan 25, 2009
-   HP C4345 ALL-IN-ONE CARRIAGW\E JAM
-   WPYJ1213
Nov 24, 2008
-   carriage jam problem-   Guest
Oct 18, 2008
-   Same issue numerous times, am trying the unplug info from Korean website.-   Guest
Best Solution
posted on Mar 06, 2007
Very Helpful)
Stretch362
Rank: Apprentice
Rating: 100%, 3 votes
stret... indicated that his solution for
OfficeJet 7110... Problem
is valid for all Printers
I just went about an hour of tech help on the HP 7110 with this problem. After resetting and all of their advice the thing will not work and says paper jam. The tech stated that it was a hardware problem. It seems that for $500 they would produce a device that will last longer than two years. I will check the above tips to see if this is what happened to my printer. Thanks for the information that you have provided.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 21, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The carriage jam that can be cleared by hitting the "Enter" key can be the result of a dirty sensor on the left side of the service station. It is a short piece of green circuit board with a rectangular metal target in the center, facing up. The ink coats it to the point that it can be nearly unrecognizable. It is easily cleaned with rubbing alcohol, or water. I prefer the rubbing alcohol because it will dry more quickly, reducing the chance of any electrical shorting. This solution worked perfectly on my D135 for the "Carriage Jam" problem.
Solution #3
posted on Jan 03, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I came across this problem too.
I googled for "carriage jam" "hp psc 2110"
and found this page on HP Korea's Support Site (the printer seems to be a Korean OEM):
http://h10025.www1.hp.com/ewfrf/wc/docum...
It has a video showing how to solve the problem.
1) unplug printer
2) push printer cartridges to far left
3) open back of printer and spin the rolls inward, then replace the lid to close the back up again.
4) while holding the enter and cancel buttons, plug the printer back in. this will initiate a full reset.
got my printer working again.
Solution #4
posted on Nov 06, 2007
Helpful)
ustuntman
Rank: Apprentice
Rating: 93%, 112 votes
This is simpler than you'd think - it's due to the rubber "parkers" under the cartrdiges' rest position being mis-aligned. Solution: 1.Whilst Printer is on, remove power cord 2. Remove power cord from AC outlet 3. By hand, move print cartridges to the left 4. Pull rubber "parkers" under where the cartridges were fully towards you. Now move the cartridges by hand left-to-right to ensure no further obstruction. 5. Connect power cord to printer 6. Connect power cord to AC outlet 7. Switch on. You may need to re-align print heads at this point but carriage jam will be solved.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #5
posted on Apr 10, 2007
Helpful)
lui55555
Rank: Apprentice
Rating: 89%, 27 votes
I got the error message about clearing the carriage and no matter how many times I turned it off, unpluged, turned in on again, checked for paper jams, etc, the printer could not get reset. But after much trial en error, the following procedure did the trick:
Unplug the power cord and open the door. To the right side, you'll see the ink tray. Carefully pull it to the center and unistall the ink cartriges. Close the door, plug in the power cord and turn the printer on. It should ask you to install the left ink cartrige first. Do it and close the door again. Then it'll ask you to install the right cartrige. Do it as well and turn the printer off again. Turn it back on, let it initialized, and your printer should be ready to work again. I hope this work for you as it did for me. Good luck.
Was this helpful?
Yes
No
7 people thought this was helpful
Solution #6
posted on Feb 12, 2006
Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3617 votes
I came across 2 common problems that bring up the "Clear carriage jam" error on different printers, both to do with gears, which are unavailable to replace-
on the d135 a lower gear on the cleaning station that gets damaged and will not activate the other gears, and on the 5110(closer to 6110) a gear driving the service station has a pin that breaks often - Under a cover held on by a couple of screws is two springs and maybe six gears. The one outside the 'sump' that directly drives the cartridge squeegee and stoppers is the one with the pin that breaks off.
good luck with it, hope this helped
Was this helpful?
Yes
No
Solution #7
posted on Dec 04, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I got the same problem. HP gave me this address:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&cc=us&lc=en&dlc=en&product=391182&dlc=en&lang=en
mayby it can help you...
KLAS
Solution #8
posted on Jun 23, 2009
Helpful)
remiya1231
Rank: Apprentice
Rating: 94%, 4 votes
I just solved this error with my computer! Unplug printer, do not turn off! Remove your ink cartridges, right below where the cartridges were are (2) filter sponges! The sponges may have excess ink piled on them, clean filters with a wet old rag or baby wipe til the clump is gone! Then, manually slide your ink carriage holder to the left side of the printer slowly, check to see if there is anything behind there also! Turn printer (paper holder side down to floor) , lightly shake if there is something inside your printer, it should fall out! Afterwards, slide cartridge holder back to home position and close cartridge door! Your printer should work fine after, that mines did!
Was this helpful?
Yes
No
Solution #9
posted on Jul 25, 2008
Not Rated)
yareya
Rank: Apprentice
Rating: 0%, 0 votes
having the same problem as well hp 2175. carriage jam ,open door,press ok. i'm frustrated with HP printers. i also have 1209
and it gives a cartridge error, light keeps blinking. not investing in hp no more.
Was this helpful?
Yes
No
Solution #10
posted on Dec 01, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Popular Solutions for HP OfficeJet 6110 All-In-One
Questions and Unsolved Problems for HP OfficeJet 6110 All-In-One
Do you recommend HP OfficeJet 6110 All-In-One InkJet Printer?
Answer
Answer
trying to install on a new pc running Windows XP. I get an error message with "RUNAS.EXE... (More)
Answer
my hp office jet 6110 all in one keeps giving me a "remove and check cartridges" message... (More)
Answer
The printer stopped in the middle of printing and it is giving me the message--ERROR Right cartridge... (More)
23 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Sep 08, 2008
chow to clear a carriage jam
Comment by odalismramos, posted on Aug 29, 2008
My carriage jam is not moving and is located in the wright side and don't move to the left side, they are looking like stock, what can I do please.
Comment by beadbecca, posted on Jun 05, 2008
I having this error message-carriage jam open door clear carriage jam and press ok . ok i've check the back and looked inside and their's no paper jam i even bought another set of inks thinking that might help but no to my frustration it didn't do anything and now i don't know what to do and hp support is too costly $35.00 for 14 days what BS!
Comment by Guest, posted on May 22, 2008
Same problem as described previously. When I open the door and press Enter the carriage returns to the left, ejects a piece of blank paper and then completes the print job at hand.
Comment by juicydbase, posted on Apr 29, 2008
My printer is having the persistent error message of "Carriage jam, Open door, clear carriage jam and then press OK to continue.
Before it had this message, in a short amount of time and very frequently the printer would sound like the carriage was smacking into the side. The other side affect was that the print jobs would end up being messed up and off latterally.
Comment by Guest, posted on Apr 28, 2008
I installed a new print cartridge and while installing the cartridges a small black piece broke off and fell under the print heads. I was able to retrieve the black piece but in three pieces.
Currently I can not clear the carriage jam error. Any help in identifying where this part goes is appreciated. I can glue it together but do not know where it is suppose to be installed at.
Comment by Guest, posted on Mar 16, 2008
I Inadvertently placed a new 338 black cartridge on the left hand side and now cannot remove it despite it being empty. Please advise asap. I am not an expert computer operator and feel I cannot handle major maintenance tasks,I have tried pressing downwards more and pulling very firmly
Comment by Guest, posted on Feb 28, 2008
413 carriage jam. Not happening. Can't print
Comment by ladya, posted on Feb 18, 2008
clear carriage jam
Comment by PiLoop, posted on Dec 28, 2007
I am having a cartridge jam error. The gears alternate between making a shorter cartridge sliding sound to a horrible grinding plastic sound as it does start up maintenance. There doesn't appear to be anything blocking the cartridge when I look inside. Now, the prompt screen is in a Pi loop of "Error, Press OK to Continue." I have pressed OK or hours and nothing changes. It won't even turn off unless I unplug it. I love this printer and don't want to get a new product from someone else if this can be easily fixed.
Looking forward to your response.
Comment by Porchadas, posted on Dec 16, 2007
Same deal, I've tried all of the solutions and nothing works. Sure saving on paper and ink though.
Comment by stymied1, posted on Dec 12, 2007
Same thing. I quit using the printer but since it's wireless I hate to toss it.
Comment by JLSeagull, posted on Dec 02, 2007
When paper jams I no really easy method to remove the damaged paper if the print head stops in the middle. By manually pushing the print head assembly to the side you gain access to pull the paper out - with some luck. The manual lacks any trouble shooting guide for this sort of problem.
Comment by Guest, posted on Dec 01, 2007
same problem as everyone else
Comment by kelble, posted on Nov 30, 2007
I'm having the same problem with the clear carriage jam is there going to be a recall on this??? It seems more common troubleshooter then others?????I have the HP PSC2175 All- In -One -
Comment by rschapmans, posted on Nov 29, 2007
clear carriage jam error. can't get rid of error.
Comment by Guest, posted on Nov 19, 2007
sounds like the same problem to me we should all get together and notify hp that they have a problem with the printer which should be recalled
Comment by kenny10, posted on Nov 03, 2007
The screnn just says Error: open door clear carriage jam and then press ok to continue. I tried to remove the ink cartrige and re-install it but to no avail. what else can I do.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
