Question about Panasonic PV-V4611 VHS VCR
Machine not accepting tapes
My machines would not accept the movies ,i would put the tape into the machine and it would go off and not play. thanks. clarence
    Scholar:
  • 124 Answers
Just a thought : check if the head isn't blocked ! It should rotate freely (without any friction). I had more or less the same phenomenon (my VCR wouldn't accept any tapes and nothing was activated if I "pushed " a tape in). The reason was here that the VCR wasn't used for a long time (a few months), but it was plugged in all the time (heated up the interior). As a result the head was a-kind-of-blocked. Nothing serious, since I rotated the head manually my VCR works fine.
Posted on Feb 09, 2006
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Ultrium LTO 3: Tapedrive won't accept tape / can't put in tape
the take up arms are not working it must go into a shop for pro fix this is a complex fault .
make sure the repairer is well trained with this type of machine as most are not
Jul 02, 2010 | HP StorageWorks Ultrium 960 LTO-3 Tape...
I hAVE 24 in DVD triple combo ^&@$DG TV. I put
You're describing what could be a loose or worn loading belt problem, most of the vcr mechanisms used in these combos use one to load the tape and thread it for it to play or record, that is why you have to keep puhing the tape untill the machine accepts the tape and you have to keep pressing play untill it starts the play function.
Sep 19, 2009 | Sylvania Televison & Video
F11 error message in ag dv2700 during play.
I've been working for hours on this machine, cleaning and lubricating the mechanism and trying various adjustments to fix related problems. If I recall correctly the F11 error is due to tape mistracking, indicating damage to same. Someone posted a suggestion that the F08 error indicated a drum relay problem, requiring professional servicing; but it also comes up on my machine if the tape tension is too high and the mechanism cannot overcome it when loading the tape. I only realised this after finally tracking down pretty well all of the bearings needing lubrication; then adjustments to the tape tension could be detected. I've got to the stage that my AG-DV2700 will accept tapes that have been recorded on that machine; playing them instantly, after the usual auto tape tensioning where the tape is FF a few seconds and then RW a similar amount, if the safety shutter is enagaged; and merely accepting them in the normal fashion otherwise. Up until this point it would throw up the F08 error whatever tape was put in; if you switched the recorder back on instantly the tape would slow FF, ie not its usual whirlwind winding, and be available for use after auto rewind at the end. If a tape NOT recorded on it is put in it still stops with the F08 error. I would suggest that trouble with this recorder is likely due the loading mechanism becoming stiff. All you have to do is dismantle it - but there's lots of tricky bits and bobs in there to watch out for.
Mar 09, 2009 | Panasonic AG-DV2700 Mini DV VCR
Go-Video VCR Problem with accepting/ejecting tapes
As with any VCR, there are rubber parts inside that have become slick. This is a simple repair for any shop. The mechanisms are Samsung ones if I remember correctly. Expect a parts cost between $20-$40. Add in the local labor rate for the total cost. This is worth the repair cost as any replacement would not last anywhere near as long. This is also a normal occurrance as rubber parts harden with age. I have repaired many of these over the years.
Dan
Jan 05, 2009 | GoVideo Go Video DVD/VCR Combo
Emerson vcr won't accept a tape
Yes, it can be fixed, but the cost may not be worth it.
There are several components which may be the problem, ranging from a gear, a sensor, the load motor, or it may even require replacement of the entire cassette loading assembly.
Without an inspection, it's impossible to tell exactly what the problem is, or likely cost to repair.
It may be much cheaper to replace the machine.
Mar 24, 2008 | Emerson EWV601 S-VHS VCR
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Panasonic PV-V4611 VHS VCR Logo
319 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
