Question about Cameras
Pentax k100 self timer use
I can not find my manual and need to find out how tp use the self timer on my pentax K100
E-man_1
  • 56 Answers
SOURCE: Pentax K10D won't work with lens from Pentax K100 (film0
The lenses are probably manual focus lenses,
  1. Make sure that the apature ring is set to 'A' or automatic,
  2. if these are manual focus lenses then switch the focus switch on the left side of the camera body to MF
  3. If this still doesn't work, or you are having trouble with the apature ring then press the menu button to go to the  menu then press the right arrow key untill you are in the  Custom Settings, scroll through the custom settings with the up and down arrow keys until about the 2nd from bottom there is an option called "using aperture ring" set this to 2 (Permitted) This will make the camera take a image when lens is on any f-stop manually.
Try this and everything should work fine. If all this hasn't worked then try seting the mode dial on the camera to M manual mode. Cheers
Posted on Sep 10, 2008
smartr10U
  • 1305 Answers
SOURCE: i purchased an SDHC card for my pentax K100 and it
Unfortunately, with the current software onboard the k100d isn't compatible with a sdhc card. It looks like it's max capacity is 2gig.
There's some hope that there may be a firmware upgrade for the camera later, but for now it's limited to 2g cards.
Posted on Dec 30, 2009
Testimonial: "Thanks"
Obertelli
  • 3006 Answers
SOURCE: How do you change the shutter speeds on an pentax
You can't.
In Auto Pict mode the camera selects the best of the pre-set Scene modes for the photograph which you're about to take. It's basically a variation of fully automatic mode, so the camera selects everything for you.
Auto Pict and Auto are designed to let anyone pick up your camera and take a fully automated snapshot without needing to worry about what settings to use.
To alter the shutter speeds you need to select an appropriate mode such as shutter priority or manual.
Posted on Jan 16, 2010
  • 11967 Answers
SOURCE: I am trying to dowload
If you go to the support section of the Pentax website, you can download the manual.
Posted on Sep 25, 2010
  • 269 Answers
SOURCE: My Pentax K100 DSLR is
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Posted on Mar 04, 2011
Why wont the pentax k100 let me use a 4gb memory card?
I believe if its an hd camera it needs an eight or the card is bad and wont formatte
Nov 29, 2011 | Pentax K100D Digital Camera
How do i change my resolution from 72 to 300 on my pentax k100 d?
You don't. Dots per inch (DPI) is irrelevant to the camera, and it sets it to 72 only because it needs to set it to something. DPI is only relevant when printing. You can set it indirectly by choosing the size of the print, or you can set it directly and let that control the size of the print. Either way, it's up to whatever program you use for printing, not the camera that shoots the picture.
Oct 06, 2010 | Pentax K100D Digital Camera
I am trying to dowload the opration instuctions for the pentax k100 camera?
Sep 25, 2010 | Cameras
How do you change the shutter speeds on an pentax k100 super, when it is on the AUTO PICT setting?
You can't.
Jan 16, 2010 | Pentax K100D Super Digital SLR Camera
I purchased an SDHC card for my pentax K100 and it does not work - any suggestions?
Dec 30, 2009 | Pentax EI-100 Digital Camera
Pentax K100 Super D clicks, but no pictures.
Hate to say it, but it's dead. My Pentax K100 D Super did the same thing. Took it to the local camera shop. They scratched their heads and sent the body to Pentax. The reply that came back was that the circuit board was completely fried and it would cost more to fix than it would to buy a new body.
I was out of luck because the warranty was out (had it a year and a half), but with yours being less than a year, you should be able to get a new body without having to shell out $$$.
Jun 11, 2009 | Pentax K100D Digital Camera
I have a pentex k1000 camera with a tamron ae 28-80 and ae70-210mm lens. They have pentex mounts on them. Are these lenses adaptable to todays autofocus cameras like the canon eos or pentex k100
If it is a pentax lens then yes but only for pentax cameras...it wont fit a canon at least not to my knolege. pentax makes all there cameas with the same lens mount.
Jun 07, 2009 | Tamron AF 28-80mm Lens
What kind of battery does the pentax k1000 35mm SLR camera take?
Yes the K100 uses LR44 or G13. I would recommend the G13
Nov 12, 2008 | Pentax K1000 35mm SLR Camera
Pentax K100 problem
Might be temporary lack of communication between lens and body - try cleaning the contacts on both gently with a lint-free cloth and a very little IPA.
Jul 17, 2017 | Pentax K100D Digital Camera
Feb 12, 2008 | Pentax K10D Body Only Digital Camera
Cameras Logo
189 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
