Apple iPod nano Logo
Posted on Sep 07, 2008
How can i get the software off the internet of my apple ipod neno
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
376
Points
5
How do you get the internet setup on the apple ipod touch ? wifi/safari dont know how to set the internet up oon a brand new ipod touch
The ipod touch connects to the internet wirelessly. To do this go to settings and the first item under the settings is denoted as Wi-Fi, click on this and then switch on the wifi. Once it is switched on click on the name of your wireless network and then insert your password and you should be able to browse the internet. Hope this helps.
tip
I have neno ipod 4 gb
when i connect my ipod to usb it will not open .and normaly i m not using my ipod because its not start so . can u short my problem
I FORGOTT MY CODE TO MY IPOD NENO WHAT CAN I DO TO
from wikihow:
  1. Plug in your iPod.
  2. Wait for it to load completely.
  3. Open My Computer (or computer if on Vista). Make sure you can view hidden files.
  4. Go to iPod_control.
  5. Go to the folder named Device.
  6. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked.
  7. Safely remove your iPod and it will be cleared.
Hopes this helps! ^_^ Please rate!
Itunes 8.0 does not recognize my ipod nano 8GB and if i try to restore to factory settings, it says i am not connected to the internet even though i am connected. Is there any other way to download the...
Check this link:
http://support.apple.com/kb/HT1320
Useful troubleshooting-video:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
2helpful
2answers
Ipod nano
Apple iPod is Locked
There is only one way - and it will erase all your songs (applies to most models, not just Nano):
If you lock your iPod nano screen and can’t unlock it
Normally, if you can connect your iPod nano to the computer it is authorized to work with, your iPod nano automatically unlocks. If the computer authorized to work with your iPod nano is unavailable, you can connect iPod nano to another computer and use iPod Updater to restore your iPod software. See the next section for more information.
If you want to change the screen lock combination and you can’t remember the current combination, you must restore the iPod software, and then set a new combination.
Updating and Restoring iPod Software
You can use iPod Updater to update or restore your iPod software. Apple periodically
updates iPod software to improve performance or add features. It is recommended that
you update your iPod nano to use the latest software. You can also restore the software,
which puts iPod nano back in its original state.
- If you choose to update, the software is updated, but your settings and songs are not
affected.
- If you choose to restore, all data is erased from your iPod nano, including songs, files,
contacts, photos, calendar information, and any other data. All iPod nano settings are
restored to their original state.
To update or restore iPod nano with the latest software:
1 Go to www.apple.com/support/ipod and download the latest iPod Update. The update
has the latest software for all models of iPod.
2 Double-click the software installation file and follow the onscreen instructions to install
the iPod update.
3 Connect iPod nano to your computer and open iTunes. The iPod Updater application
opens.
If you’re using a Windows PC and the iPod Updater application doesn’t open
automatically, you can find the updater by choosing Start > All Programs > iPod.
4 Follow the onscreen instructions to update or restore iPod software.
If you use the iPod Updater application and it doesn’t recognize that iPod nano is
connected to your computer, reset iPod nano (see page 45).
If you want to restore iPod software and you don’t have an Internet connection, you
can use the iPod Updater application that was installed on your computer when you
installed the software from the iPod CD.
-Tha Mp3 Doctor
23helpful
3answers
Apple Ipod Software
i want apple ipod 2gb - A1204 software
3answers
Please help
If you don't know the password, the way to unlock it is to do a restore:
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Ipod download
You could try this site to download the itunes software and any other required/additional software you would like. http://www.apple.com/ipodshuffle/
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
