Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Dishwasher stopped mid-cycle
Our 4-yr-old dishwasher (Whirlpool 24-inch DU1100XTPQ) stopped in mid-cycle. A small amount of soap was still in the opened soap case and lthere was standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. All of the other electrical appliances in our kitchen are working. Linda Peterson lafpete@roadrunner.com
  • LUSHMAN001 Sep 11, 2008
    Our 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
  • boriana Jan 05, 2009
    Same problem with 4-yr-old Kennmore Elite
  • 530 Answers
You have a bad thermal fuse in the control panel. it's the whit thing with 2 wires going to it
Posted on Jan 04, 2009
  • 1 more comment
  • erica graber Jan 29, 2009
    take the screws out from around the inner linner of the door tto access the control panel, peel apart the 2 peices of the door. make sure you have no power turned on. on the right side you will see a black box usually. Take that off to access the fuse. The fuse is attached to the computer board if you have an ohm meter check continuity with the 2 wires detached from the fuse. Either they are 2 brown wires or 2 white wires. This should fix it
  • Mark Fontana
    Mark Fontana Dec 07, 2013
    checking continuity will fix it how? what would we do with the continuity reading?
  • Bruce Reffitt
    Bruce Reffitt Apr 24, 2017
    I have replaced the fuse. It blew again the very next run in mod cycle. Bought another fuse. Tested the heating element after unplugging the power leads. It's continuity is good. There is not short to ground.
    Any clues on what is blowing this circuit board?
The soap dispenser isn't opening all the way. Therefore it leaves a small amount of soap in the chamber after the rinse and dry cycle. How do I fix it?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Feb 20, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
8 yr old GU1200 stopped mid cycle - no apparent reason - no response to buttons - appears dead?
These dishwashers have a thermal fuse in the control panel. If it overheats for some reason (sometimes a bad connection on the fuse itself causes that)it will turn whole machine off.
  1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
  2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse. Here is your part
Good luck
Vlad
First Choice Appliance
Sep 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap
Your soap is old. Get some fresh stuff, or use a liquid dw soap
Jul 24, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
No power
Hi lushman001
I'm Harvey the Master Plunber.
Your question is: your 3-yr-old dishwasher (Whirlpool 24-inch ) stopped in mid-cycle. A small amount standing water in the bottom of the washer. None of the control panel buttons were lit up and none of them will work. NO POWER
First check all the breakers (or fuses).
Second check the electrical connections. If you're not a qualified electrician or service tech then call one. It"s under the unit behind the kickplate.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
1,290 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
