Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Display When I powewr up, I got Lenovo loga apear few secnd then diplay is blank.
  • RyanTM Mar 06, 2009
    Screen reads:
    We appologize for the inconvenience, but WIndows did not start successfully. A recent software or hardware change may have caused this.
    If your computer stopped responding, restarted unexpectedly or was automatically shutdown to protect your files and folders, choose Last Known Good Configuration to revert to the most recent settings that worked.
    If a previous startup attempt was interrupted due to a power failure or because the Power or Reset button was pressed, or if you aren't sure what caused the problem, choose Start Windows Normally.
    Safe Mode
    Safe Mode with Networking
    Safe Mode with Prompt Command
    Last Know Good Configuration ( your most recent settings that worked)
    Start WIndows Normally
    Use the up and down arrow keys to move the highlight to your choice.
    Seconds until windows starts: 30
    **Each selection was highlighted and attempt. Each attempt resulted in the Windows Icon appearing then returing back to the screen with the above directions.
    Also I tried pressing the rescue and recovery butoon (F11) and the same result occured.
    Do you have any suggestions for this problem?
  • Gerhard Stoll
    Gerhard Stoll May 11, 2010
    Are you able to enter the bios?
    When you enter to the blue Lenovo Key.
    Can you look with an light if only the backround lamp of the LCD is bad ? Shine wiht an lamp on the lcd an describe if you see anything.
    Problem Solver:
  • 9 Answers
Open the tower take out the ram and then put it back and then restart the system and check whether you are facing the same issue or not and try to restart the system in safe mode.
Posted on Feb 21, 2010
Does this model have mini diplay port to use in connecting to tv with hdmi
You cannot connect mini display to HDMI they are different standards.
Mar 18, 2015 | Lenovo ThinkPad T410 Notebook
Lenovo ThinkPad T60 goes to blank screen at random intervals.
Hello you just have to upgrade the driver for the graphic card.
You can also use windows update
Visit lenovo here:
Or use the autodetect function
http://support.lenovo.com/en_US/detail.page?LegacyDocID=MIGR-62928
If it not helps with the driver your display has a defect
its not a easy task to change the display.
The local computer repair shop should be able to help you with that.
Good luck
Aug 14, 2012 | IBM ThinkPad T60 Notebook
Unable to load on screen display on lenovo r500
What do you mean unable to install on screen display? Are you saying your screen is blank?
Maybe you need to reinstall the video drivers.
Get online and got to www.google.com In the google search box type: "IBM Support" or "Lenovo Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Download and install the Video drivers.
If you are saying that the system boots up and everything seems to be running except the screen is blank then try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 14, 2012 | IBM LENOVO ThinkPad R500 - Genuine Windows...
My external monitor was not working. I tried to change the settings within the display, rebooted, and now both are blank. I have tried to reset the emos (?) to the factory default and nothing changed....
I am not sure if this works but worth trying: 1- Turn the laptop on and while holding Esc key for about 1 mins. 2- Wait few minutes for boot process. 3- (if still no display) Hold Fn key and hit f7.
Jan 13, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Model RBD245PDB14 Error code F2 E6(left side) replaced original key pad with new. One week after install same error code and display blank out. Unpluged and reattached key pad cable but still diplays F2 E6...
If you replace the keypad and continue to have the same error you also have to replace the electronic control.
You can contact fixyourboard. com for a price to repair your control at a reduced price over a new control. It also comes back with a better warranty than anew control.
Jan 03, 2010 | Whirlpool Ovens
Water damage touch screen not working think its getting worse as sometimes does not read game 1st time and screen goes blank sumtimes 2
Friends,
Water damaged screen means total loss, You must have to chage screen. First time while you switch on it water is presented on TFT display, And its damaged to diplay & normaly is blank sometime. Check it in service center of it.,
Thanks.
Sep 23, 2009 | Nintendo DS Lite Console
Lenovo 3000 n100 notebook display problem
Appears the backlight for the LCD display has stopped working. This usually needs to be replaced by a professional unless you are electronically and mechanically savy.
Jul 10, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
White Screen for Lenovo Y410
can you try and power up in safemode
by continuosly pressing f8 during startup
see if you can get in safemode
Aug 31, 2008 | Lenovo 3000 Y410 (59012354) PC Notebook
BLANK DISPLAY
Did you try to adjust the contrct knob on the contoral pannel????
May 19, 2008 | Canon imageRUNNER C3200 Copier
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
98 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
