Question about X2Gen MG19MY 19" LCD Monitor
Monitor cannot be turned on
II have an X2Gen MG19VT 19" LCD
onitor purchased 1/30/06. Problem: The monitor does not go on9the screen is black). The AV adaptor shows a flickering light however no current is going thru to the monitor. The AC adaptor is made by Powertron Electronics Corp(PEC). Model # AD1250B. Input:100-240v-1.28 amps -61050Hz Ouput: 12v-4.17amps-50w max.
I have diconnected from computer given it a rest and the reconnected with no results. All wiring and adaptor checked for correct attachment.
  • Anonymous Jan 24, 2009
    I have the exact same monitor and problem, I moved my monitor to a different room, and now the monitor wont register the power supply. It worked perfectly before. The AV adapter light is pulsing green like normal. Should i replace the power cable? or is it more likely something broken on the inside of the monitor itself.
  • 905 Answers
You will need to check the power adaptor for voltage , if that checks out then you will have to check the power circut in the monitor, look at the protection component and diodes in the power circut
Posted on Oct 06, 2008
My power cord does not work anymore, i need to purchase another one, i was wondering what the price would be
http://cgi.ebay.co.uk/12V-X2Gen-MG19VT-replacement-power-supply-/400197777357?pt=LH_DefaultDomain_3&hash=item5d2da577cd
Mar 03, 2011 | X2Gen MG19VT 19" LCD Monitor
Black screen
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 15, 2010 | X2Gen MG19MY 19" LCD Monitor
Where can I find a copy of the manual for the X2Gen MG19VT
google it.
In case you want to avail a free technical support,
just get in touch with one of the techbuddies they provide free
technical support, you can find them on http://tinyurl.com/n29l7c
Jun 18, 2009 | X2Gen MG19VT 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Defect in AC adaptor
Traggio,
It's seemd you need a new AC Adapter. You can get a new Universal AC Adapter for your LCD monitor. Check out this website @ www.3rd-rocks.com
Sep 07, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen MG19MY 19" LCD Monitor Logo
176 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
