Panasonic PT-47WX51 47 in. Rear Projection Television
Problem for Panasonic PT-47WX51 47 in. Rear Projection Television
Red ghosting
By fartmonkey on Feb 07, 2006
i have a panasonic 47wx51 hdtv .the problem is a red ghost effect after i turned on one day.is there anything i can do or should i bring it to a teh for repair
Solution #1
posted on Feb 07, 2006
Somewhat Helpful)
silly girl
Rank: Wiz  Panasonic Expert
Rating: 81%, 3608 votes
Technically speaking, there is no such thing as "ghosting" on digital TV. Ghosting might visualy describe it, but if you're not watching analog then that's not the problem. The problem is most likely in the convergence.
First thing first - If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages.
If you don't have any repair experience my suggestions can only be usefull to get a repair estimate, or in order to get more familiar with these kind of problems, impress your local repair person etc...
some common fixes:
switch to test mode to check the red crosshair compared to the green or blue - if it seems out of focus, open the set and mark the position of the lense. Then adjust it to tighten the line.
Find out why the Red has shiffted(pin trouble). look for bad solder joints on that board. Its also Possible that you have a failed component.
Try resoldering the STK Output IC's very carefully.
In a worst case scenario , you may need to change the STK that controls the Red Convergence .
Yank out the convergence board(the one that has several
controls) on it, then you will find a few contols that have RED PIN
(whatever). on them. Adjust them untill you get it right.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on May 29, 2008
Not Rated)
nipper00
Rank: Guru
Rating: 91%, 60 votes
the problem is the convergence IC's - the are located (from the back) on the left toward the front of the set - i always change bolth at the same time - there might also be an open resistor in front the the ic that fas gone (2.2ohm i think) it should look burnt - on another note do not adj any thing in side the set!!!! the controles silly girl is talking about are not in your set - if you can not solder please do not attempt - if there is any thing i can help you with let me know
thanks
scott
Was this helpful?
Yes
No
Solution #3
posted on Sep 14, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
call a service man it will be cheaper in the long run
Popular Solutions for Panasonic PT-47WX51 47 in.
Questions and Unsolved Problems for Panasonic PT-47WX51 47 in.
Do you recommend Panasonic PT-47WX51 47 in. Rear Projection Television?
Answer
Answer
I have a Panasonic PT-47WX51E on I was wandering it says HDTV on it and it says 1080i. I have a PS3... (More)
Answer
tv shuts off a couple of seconds after turning it on, smoke comes from far left side but I cannot... (More)
Answer
Banner at the top of the screen is cut off. Need to reduce vertical size of picture.
Answer
Im seeing double on the screen. When trying to adjust the convergence the green lines quickly curve... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic PT-47WX51 47 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
