Question about Friedrich Heating & Cooling
Hi, I've an older but great friedrich Quietmaster SS12J10. The front grill is held in place by two separate white plastic holders that screw into the actual unit, that the grill then "clips" onto. I need to replace both plastic little units. Would you know where I can I find these parts? (Otherwise the front grill doesn't stay on.) Thanks very much. Elijah
  • 166 Answers
As you requested here is a parts order #
Toll Free 800-3383790
If its in stock they usually get it to you next day if you ask!
Bless You
Please rate my good service before you sign off!
Thank You
Posted on Sep 07, 2008
Replace cord in Rowenta Iron
0) Unplug the iron.
1) Remove the (2 or more) screws holding the plastic bottom plate (that the iron stands up on).
The screws are likely to be #20 Torx "Security" screws -- for which you will need a special bit for your nut/screwdriver. A kit of various sizes of Torx security bits will cost you about $10.
2) Remove the plastic cord-holder assembly from the iron.
2a) If the cord-holder is held in place with screws (you are in luck!), simply unscrew them. If you see no screws, then it is being held in place by several (probably 4) plastic tabs that you must simultaneously release. This makes the job much more fiddly. Use a small/medium blade screwdriver to carefully bend and hold each of the plastic tabs out of the way of the latches. You'll need one screwdriver per tab/latch! Take care not to break the tabs...
2b) Carefully wiggle/pull/work the cord-holder assembly out of the iron taking care not to bend the pins of the integral plug (inside the iron) that are seated in the cord-holder socket. Basically, with the iron resting on its metal surface, pull/pry/wiggle the cord-holder straight upward until the cord-holder (socket) pulls free of the (3 or more) stiff wires that function as a "plug".
3) Note that there are 2 crimp-on connectors attaching the 2 wires of the cord to the rest of the wires in the iron. Take a photo of the wires and jot down notes of which wires are connected together. NOTE: One of the cord wires is "neutral" and is attached to the wider spade at the plug end of the cord. Typically the "neutral" wire is marked with a white stripe or ridge down length of the cord. Don't mix up the "neutral" wire and the "hot" wire when you re-connect them in a later step!
4) Cut off the crimp-on connectors and separate all the wires.
5) Remove the cord from the system of zig-zagging "strain-relief" notches that hold the cord securely in place. You may have to remove a small plastic clip first.
6) Cut off 6 inches of the cord. (Or supply a new cord, if the cord has been shortened too much in previous repairs.) This eliminates the broken section wire within the cord. You may use an ohm meter to verify that both wires have a low resistance again (less than 1 ohm).
7) Route the cord back into the "strain-relief" notches in the cord-holder. Don't forget the plastic clip (if there was one)...
8) Strip all wires, exposing about 3/8" of copper on each.
9) Referring to your notes and photo, re-connect all wires using proper-sized plastic wire-nuts for secure connections.
10) Re-attach the cord-holder to the iron body. Make sure you line up the stiff wire pins with the cord-holder socket. Push the cord-holder into place and secure it (via screws or snap-in-place plastic tabs).
11) Replace the plastic cover, taking care to position the wire-nuts and wires to allow it to drop into place without forcing it. Secure the cover with screws.
12) Plug in the iron and test it out!
Mar 23, 2014 | Rowenta Irons
Our Freidrich air unit is very old but still works . We can't find out where the filter goes or comes out so we can replace it or wash it out. Where is the filter located? Does the front of the unit come...
On a older friedrich unit, located on the plastic front should be a flip down grille with the filter located in front of the evaporator coil. The evaporator coil looks kind of like a radiator and this is actually what the filter is for: to keep the evaporator clean. (The filter should be right behind the plastic front and right beside the knobs)
Apr 16, 2011 | Friedrich WallMaster WS07A10D Air...
Hi! I have a Freidrich Quitmaster, SS12J10. The condensation water is flowing back into the apt..I think that the drain hole is clogged, I will be pulling the unit out to clean, but would like to have any...
The drain holes are usually in the back corners of the pan and many do allow some water to remain in the pan to help cool the condensaer coil...
Aug 29, 2010 | Friedrich QuietMaster SS12L10 Air...
How to remove front cover for cleaning
I don't know too much about your particular make / model but most window units have a 1 piece front cover which is usually held on to the main cabinet with 1 or 2 screws at the sides and 1 or 2 behind the filter panel. You will need to remove the front panel to remove the vents as they are usually fitted from behind the panel.
May 31, 2010 | Friedrich QuietMaster SM18J30BR Air...
How do I access the power window switch
I remove the silver speaker grille cover 1st. pick a place by the front bend ( by the cup holder in the door ) and insert a plastic trim tool in, and pop it loose. If you do not have a trim tool, a plastic putty knife usually will work, last resort should be a screw driver, this can mark the plastic.
Once the speaker grille is off, the switch panel is held on with spring clips on the side facing into the truck. Place the trim tool under the edge of the switch cover, and turn anti clock wise. This will release the spring clip, do the same for the other one.
At this point, the tabs on the side towards the door can be picked up, and pulled out, freeing the switch panel from the door.
Feb 14, 2010 | 2004 Ford F150
The switch on my Friedrich Quietmaster panel is
you can find them at any A/C supply house for window unites or on line. try Sears
Jul 14, 2009 | Friedrich QuietMaster SL36L30 Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
Everything was great- but wrong tel number!
Discount Parts Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Sep 08, 2008 | Friedrich QuietMaster RS10J10 Air...
My husband figured out that the grilles themselves click out--not the whole assembly. Now he is going to have to figure out how to click it back in!
Jul 01, 2008 | Friedrich QuietMaster Electric SS10J10AR...
Heating & Cooling Logo
366 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
