Question about Mitsubishi WS-65807 65" Rear Projection Television
Won't power on...
We turned off our TV last night and went to turn it on this AM and the green power light will flash for a few seconds and then automatically power off. It was stated in previous answers to check the PC board (which I have no idea what that is) or to contact a repairman. First, this TV was left by the landlord who didn't want it so I doubt he will want to pay for any repairs and I can't afford to repair it either. Any other troubleshooting I could do on my own to figure out what the problem is or how to fix it myself? Thanks! Jenny
  • MBP1025 Sep 28, 2008
    EXACT SAME THING IS HAPPENING TO MY TV. I BOUGHT IT 2002. WISH I KNEW WHAT THE PROBLEM IS.
    Problem Solver:
  • 6 Answers
Unplug the TV for a minute then plug it in while observing the power light. If the light flashes three times then the standby power supply is OK.
If the standby power supply is OK, a diagnostic code can be read from the green power light by counting the flashes. Press the power button once (this sets the diagnostic code). Press and hold the INPUT and MENU buttons on the fron panel for 5 seconds then release. The green light flash a two digit code (x flashes, followed by a pause, then y flashes). If it flashes a 2-2 code then a short circuit has been detected in the switched power supply. It would normally flash a 1-2 code for "no problem detected".
If a 2-2 code is read, check for blown pico fuses on the POWER circuit board. If the FA904 or FA905 fuses are blown then most likely at least one of the two convergence driver ICs are bad. It seems like this is the most common failure. I replaced these fuses and ICs in my TV. The parts cost me $50, but it required extensive disassembly, PC board desoldering & resoldering, and reassembly. If you can resolder circuits on a PC board then you can probably fix it yourself, otherwise call a repair person.
Posted on Oct 06, 2008
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Flashing red light
Same problem with my Sony. Unplugging for 36 hours solved the problem
Oct 05, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Blinking power light.
i hve the same problem. I turned on my Sharp Aquos lc-32d62u HDTV last night for the first time, but it is black and a blinking green light.
did you find a solution?
Mar 06, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV WENT OFF BY ITSSELF
This may denote a proble in either your switching powers supply or your Horizontal section derived high voltage power supply. These are both very dangerous sections in your television. My next question is important; do you have a background in electronics? If not I would not advise you working on this problem yourself and that you take the TV to a repair shop for servicing. If you do have some background in electronics, I would like for you to make the following obeservations: What was the TV doing (it actions)prior to it going out? Did you hear any sounds before it went out like buzzing or crackling? What do you hear when you try to turn it on now, clicking? These questions are just to develop some background into what might be happening to your set. Thank you, Shuttle83
Oct 07, 2007 | RCA 32V524T TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
167 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
