Green Blinking power light
When you go to turn the tv on it makes to clicking sounds and the power button will blink green at that time but will never actually power up. Do you know what this could be?????????
    Problem Solver:
  • 7 Answers
The set is faulty probably at the line trans section, send to a repair centre.
Posted on Sep 20, 2008
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
When I turn on my 50" Plasma TV the light goes from red to green. The Green LED flashes 14 times then solid. There is a white raster but no picture or sound.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 16, 2015 | Zenith Z50P3 50 in. Plasma TV
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
