Question about Water Heaters
Instructions for my Ideal Mexico CF60P Propane boiler
Help!
Where can I download instructions/user manual/installation guide for the above boiler please? It isn't heating my hot water very much an I wanna figure out why if possible. Cheers very much.
Marie x
  • crbyl Dec 25, 2008
    there is a red light on the heater and we have no hot water A red light keeps flashing
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi tessajoe,
I'm Harvey, the master plumber. You asked where you can
Ideal Mexico CF60P Water Heaters. I believe this is the correct link:
http://www.chspares.com/partselect.php?test=121
Some Companies will e-mail it, others will respond if you call them on the phone and they will fax it or mail it. Contact info on the link that you requested form me.
I'm happy to help you!
Feel free to contact me.
Harvey the Master Plumber
Posted on Sep 09, 2008
Ideal mexico boiler HE 36
Check Gas Pressure, make sure you have correct pressure.
Apr 06, 2014 | Water Heaters
Stelrad ideal mexico boiler
Trying to look that unit up. I believe it is obsolete. IF there is an electric motor on this unit, I would check that first. Motors are the biggest consumers of electricity and they have moving parts. If there are no motors then you need to check any electric ignitors that are present. They step voltage up and can short out. This means that you should have some way to test things. Using something like a meter is good
Jul 18, 2013 | Water Heaters
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
I have an older model Ideal Mexico 2 floor standing open flue boiler running a fully pumped system. The central heating isn't working properly despite being flushed etc. The initial problem is still there...
You could undone the return at the boiler to release any air ? if you think there is a air lock . Or turn the pump up to max with the heating on and try to push the air out .
Jun 08, 2017 | Water Heaters
Missing instructions for setting timer on boiler
if the timer is built into the boiler there is a small switch on the right hand side. this can be moved up and down to bring the timer on and off.
if you log onto the ideal web site you should be able to download a copy of the programing instructions.
Feb 21, 2009 | Water Heaters
Water Heaters Logo
918 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
