Question about Dryers
Need electrical schematic for kenmore model#110.62212100 electric dryer (type D433)
    Genius:
  • 1,028 Answers
Did you ck under console? pull end caps off remove the screws under each roll console back
Posted on Sep 07, 2008
I have a whilpool electric dryer type d433-2406026-fm54 this dryer doesn,t heat anymore but the dryer still runs.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,,.';'
Aug 02, 2011 | Dryers
I have a whirlpool Dryer type: D433-ELE-2406028-FM54, Model: LER463JQO. It takes atleast 2 cycles to dry the whole load completely, and I'm wondering what I can do to fix this problem?
You may have a clogged vent pipe. I would take it apart and clean it all out.If that doesn't help then you may have other problems.Could be thermostat or one bad element. Hope this helped.
May 05, 2011 | Kenmore 600 6965 Electric Dryer
No heat, everything else is fine whirpool module R6X3519PQ0 Type: D433 Thank you Bert
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 11, 2010 | Whirlpool Dryers
Kenmore Dryer won't heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
Schematic model 110.64992300
Schematic is either on the inside of the back panel or front panel.
Eric
Jun 20, 2009 | Kenmore 64992 Electric Dryer
Need amperage draw and plug configuration for whirlpool dryer
Electric dryers all use the 30Amp plug and rated wire depends on length of your run and local building codes.
Jun 08, 2009 | Dryers
MY KENMORE DRYER WON'T DRY MY CLOTHES
you need to clean out the dryer vent hole and the wall vent hole,that is your problem it's not letting the wet hot air out-mike
Mar 31, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
331 people viewed this question
Top Dryers Experts
