Question about Casio Exilim EX-S500 Digital Camera
Lens Error My cameras battery was low but I kept taking pictures until the camera shut off by itself. The lens didn't retract all the way and now when I try to turn my camera on it makes a clicking noise like the lens wants to move but it doesn't and on the back screen it states a lens error. I am not sure how to resolve this problem I have charged the battery and taken it out. I unfortunately do not have the manual on me.
I have exactly the same problem with my camera, except there is no error message - just the screen is off (bat is full). i cant find a soultion anywhere in the manual or online. Any help on this would be much appreciated.
Posted on May 02, 2006
  • 513 Answers
First of all the manual is available on this site, in case you'll need it in the future. the manual says that if you have a "lense error" message it means the lense is obstructed, i'm guessing against it in your case, but its worth while checking to see if theres nothing jammed in its track. it's actually a known, and common problem with these small casios. i heard that a quick fix is that when it happens the camera battery has to be removed, and that should clear it, but the problem can also return, and after a while that trick won't do the trick any more. if you want to have it fixed while still in warranty don't wait to see if any of the common "blow air into the..." or "use some epoxy" fixes help you, you can try all that later. good luck
Posted on Feb 06, 2006
Kodak easyshare Z650 lens extends and retracts
I only can think of two reasons. The first, the battery does not have enough power. As a safety precaution it shuts itself down, to avoid damage to the saved pictures. Because if the voltage is to low, it can't write with 100% accuracy.
Second: something is blocking free movement of the lens. This could have a cause inside the lens barrel, and you won't see a thing. It also could be a minute damage on the outside of the lens. Or what sometimes happens while putting the camera on, you touch the lens barrel. I assume you did remove any lens cap attached to the camera.
So if you can't see any damage to the lens barrel, charge the battery and try again.
Jan 30, 2014 | Kodak EasyShare Z650 Digital Camera
Lens error. lens is currently retracted. will not open. nikon s8100 bought xmas 2010.
Had issue with lens stuck and not retracting on nikon s8100. first removed battery. then manually (gently) rotated lens counterclockwise until lens seated in fully retracted position. inserted battery, turned camera on and camera operational again. I suspect that root cause of lens jamming was turning off camera while simultaneously moving zoom lever
Mar 11, 2011 | Nikon S8100 Digital Camera
Samsun sl201 lens will not extend, then camera shuts down
If the camera's lens will not retract out, then eventually shuts down, here is what you try to do.
Hold the camera from your right hand with the lens facing down. Then tap the base of the camera to your left palm while turning the camara on; do this several times until the camera's lens retracts out.
This problem often occur when the camera was taken outdoor or in the beach. Sand or a tiny granule of dirt might got stuck in the base of the lens.
Sep 25, 2009 | Samsung SL201 Digital Camera
Canon G9 dropped
I was told it happens when the battery is low
Aug 20, 2008 | Canon PowerShot G9 Digital Camera
My nikon says lens error
my camera says lens error. the lens is also stuck in the position as if it where taking pictures. it will not retract.
Jun 16, 2008 | Nikon COOLPIX L5 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Lens retracts when turned on
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Nov 11, 2007 | Canon PowerShot A75 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
[Casio Exilim EX-S500] Lens will not retract
Nearly one year!
Then be quick and send it back under warranty - waste no time.
May 22, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 Digital Camera Logo
599 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
