Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
The circulation fan is VERY noisy
The fan that circulates the air in the refridg part is very noisy. Can it be fixed??
  • Anonymous Feb 16, 2009
    my fan is very noisy due to ice build up around it
  • 76 Answers
You can try to fix it by oiling the fan but they dont last really long.
The best thing is to replace it,its not to expensive to buy and you can do it your self.
Regards
Wouter.
Posted on Sep 11, 2008
The freezer is cold but why is the refrigerator warm?
Likely, either your circulation fan has stopped working due to icing, or you have ice buildup in the cold air duct between the freezer and refrigerator. Try unplugging your refrigerator overnight with the doors open, mop up any melt water with towels, then plug the refrigerator back in next day. Listen for the circulation fan in the freezer and, if it is not working or not moving air, replace the circulation fan.
May 21, 2015 | Refrigerators
Fridge/freezer Samsung3116NW very noisy from left fridge wall Ithink
if the left side of your fridge is the freezer compartment , chances are you have a bad circulation fan . I would suggest replacing the fan motor assembly . The circulation fan is located at the rear of the freezer mounted to the evaporator cover .
Feb 19, 2011 | Samsung Refrigerators
Amana ABD2533DEB Bottom Freezer - Fridge not working
Sounds like the circulating fan is either gone or is going bad. This problem is hard to diagnose because sometimes the fan will run but not fast enough to circulate the air through the freezer and refrigerator. I would have your repairman look at this or if you have the know how then you can order the fan and replace it yourself.
Aug 22, 2009 | Amana ABB1927DE Bottom Freezer...
Fan underneath frig is running but no cold air is coming into the frig or freezer
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Jul 31, 2009 | Refrigerators
Maytag bottom freezer. Freezer cold, refridge. not cold. De-iced freezer. Why does this continue to happen?
Sounds like your Freezer Fan is wearing out. When this happens it is very hard to diagnose. The reason is that the fan is turning, but at far less rpm's then iss necessary to keep the air circulating thru the freezer and refrigerator. Then minimum cost to repair/replace this fan is $300.00. But this will releave the problem.
Jul 28, 2009 | Refrigerators
Refridgerator side is not cooling, freezer section seams fine
sounds like the freezer/frig circulating fan is wearing out, when this fan motor starts to wear out the rpms are reduced to a point that it will keep the freezer cold but does not have enough power to circulate the air in the frig. The minimum cost to fix this problem is around $300.00
Jul 11, 2009 | Refrigerators
The fridge section is warm, the freezer is OK
sounds like the circulating fan is wearing out. This fan supplies circulation for the freezer as well as the refrigerator when the motor for this fan starts to wear out the circulation supplied is reduced to a point that the freezer will work but not the refrigerator because the fan does nnot run fast enough to circulate the air thru the refrigerator. The minimum cost to repair/replace this fan assemble is around $300.00
Noisy Motor
The compressor is normally pretty quiet, more of a deep hum so the noise is probably coming from either the fan that circulates air inside or the one that pusshes or pulls air through the evaporator coils under the cabinet. Probably has Chinese fan motors by now -
Sep 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Noisy fan
Regards
Wouter.
Sep 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
127 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
