Question about Lexmark Office Equipment & Supplies
On the 5400 lexmark if a paper jam occured, how do you fix it,do you have to unscrew the back in order to get the paper that has jamed?
    Sergeant:
  • 241 Answers
No just pop of the back tray and you should have access to it from there. Make sure though to unplug your Printer and your printer need you to reset it.
plz rate thank you
Posted on Sep 07, 2008
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Has paper jamed in machine can not acess paper though any of the openings can see the paper though front bay it is jamed in between front rollers.
Not seeing this machine, if the drum can be taken out this can help.
If nothing can be taken out, be very careful when attempting to pull the paper out. Paper can scratch the surface of the drum and can pull stripper fingers out of place. Also there may be mylar fingers in place that may be bent or broken off causing further jams.
Using long pliers might work.
More description of this area needs to be given in order to pull this paper out. There might be other internal parts that need to be checked in order to keep this type of jam to occur again.
If al else fails place a service call by a copier service representative.
Oct 07, 2009 | Canon Office Equipment & Supplies
The problem is a paper jam
If it says there is a paper jam and there is no paper jamed. Then try opening and closing any compartments on the printer, this resets faults like a "paper Jam".
Sep 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can't see Paper jam
Open the top cover to see the jammed paper. If u wont see the paper then you have to open the cabinet of the printer . After opening remove the paper
cheers
Jun 23, 2009 | Lexmark X2470 All-In-One InkJet Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
My lexmark 5400 keeps saying "clear carriage jam". I cannot see anything jammed but i can't use it till whatever is cleared. please help!
  1. Press Power to turn your All-in-One off.
  2. Unplug the All-in-One.
  3. Check for paper jams.
  4. Plug in the All-in-One.
  5. Press Power to turn the All-in-One back on.
If the error exists .. then printer is defective contact lexmark ..
Mar 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Paper Jam
Open all the doors and remove any removable assemblies. Use a flashlight and some compressed air to try to locate the paper shard.
Jan 15, 2008 | Brother Multi-Function Center MFC-240C...
Different kind of paper jam....
Hello I have an x6170 when I go to print the paper is going in side ways, crumbling the paper. I did not do anything different from before. I tried taking it apart but I do not see any screws or if it is just snap in I would like to see the assembly manual so I can open it...maybe fixing it.
Please HELP
''James B.
Nov 28, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
67 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
