GE 25GH350 television - HOW TO RESET CHANNELS TO RECOGNIZE CABLE???
I purchased a GE 25GH350 television from a hotel and today had my cable service setup. I went and purchased a GE universal remote (which I didn't have to even program) and was able to change channels. However, when I hit the menu button on the TV or remote it only brings up two choices: Controls & Alarms. It does not have an option for me to go in and setup channel. PLEASE HELP!!!
  • 2 more comments
  • Anonymous Nov 13, 2008
    same
  • kusumpat Jan 06, 2009
    I have ge 25gh350. Chanel 4 is blocked need unblocked
  • creaturekpr Jan 12, 2009
    Have the same problem with a ge 25gh350 tv I purchased at a garage sale today. only get 13 channels of static and menu offers the same options. Found out through research this model ONLY comes from hotels and that is why it has restricted access but still searching for solution.
  • Anonymous Apr 15, 2009
    same
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
tvtek
  • 1284 Answers
SOURCE: Locked out TV channels
Need a make and model to determine what codes needed to unlock.
Posted on Jan 22, 2008
  • 52 Answers
SOURCE: won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Posted on Mar 07, 2008
  • 4234 Answers
SOURCE: doesn't get all cable channels
With the menu set to cable signals, the autoprogram should catch all of the cable channels. The Cable Channel option allows you to use either channel 3 or 4 as the "cable" channel. This is when you have an external box that you use to tune in cable rather than the TV directly. The easiest way here is to autoprogram the TV while playing a VCR tape. That will insure that channel 3 is included.
Does the autoprogram fail?
Dan
Posted on Aug 20, 2008
SOURCE: Philips PC7225 hotel TV - can't access the menu to reprogram it.
The code 0621 isn't working for the PC7225 TV on my philips RC19335027 remote. Is there any other code I can try.
Also I purchased an RCA - RCR311BT remote and programmed for the tv and the code 0621 isn't getting me to the setup menu.  Is there any other code I can try or special way to enter the code in to get to that setup menu?
The ultimate goal is to change the default startup station from channel 53 to channel 3. Thanks.
Posted on May 06, 2010
I have cable. The autoprogram doesn't recognize any channels. It works fine when I hook up the dvr cable box, but not when I bypass the box. Trying to do away with the box.
Cable signals today are encrypted so that it is not possible to directly connect the cable to the set and get the cable channels. You must use the cable box. Some sets have what is known as a "cablecard" slot that can be used with a card from the cable company in lieu of a cable box. Only then can you use the TV tuner for cable channels.
Oct 04, 2015 | Emerson LC320EM2 32" LCD HD Television
How can i factory reset a hotel lcd television with no factory reset opition?
You need a TV remote to select the input source from TV antenna signal.
Jul 12, 2014 | LG 42LC5DC 42 in. LCD Television
Brought a GE model 27gt722 tv...can not pick up all channels on cable. Usually once you hook up cable wire to tv cable is automatically on ..at least that is how it was on old tv
Depending on the cable company, some like Comcast have gone mostly digital meaning when you connect the TV directly to cable without a cabe box you will only get around 35 channels. The only way to get around that is to get a cable box. If you have Comcast service already they offer what they call a DTV cable adaptor which will allow you to get most cable channels. These DTV adaptors in most areas are free for the first two per household. I hope that helps : )
Jul 25, 2011 | GE 27GT722 27" TV
I have the remote for my 21 inch philips hotel tv but there is no menu on it so i cant search for channels. can someone help me
The menu inthe remote is taken off from the remote control pad as the management does not want clients to keep tuning or change program settings which can result in customers calling for technical help all the time.
So if you are in a hotel just call up room service as they can come over with a regular remote to help? but then if all channels on the cable is seen , what is the need for?
Sep 14, 2010 | Televison & Video
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Can't auto program Zenith TV for cable channels
  1. Did you try to call LG/Zenith customer support and see if they can help you? If not find your nearest LG/Zenith service center (not Best Buy) preferably a small service shop to see if they have a service remote to unlock it
Aug 23, 2009 | Zenith Z37LZ5D 37 in. LCD TV
Hotel TV
check in preset under menu the channels 30 above maybe skip, set this channels to skip off. or just do the auto tuning.
Jun 11, 2009 | Zenith C27A24T 27" TV
I have few tv but it has only 36 channels. it is from my other hotel .. i try to set it up and i did i got all cable channels too. but when i turn off and turn on again all i can see is only 36 channels...
call the cable company that is providing cable to your new hotel , and ask them what the problem is , if could be that someone fiddled with outside wires of your old hotel , hope i helped sincerely John
Aug 01, 2008 | Televison & Video
Televison & Video Logo
763 people viewed this question
Top Televison & Video Experts
Electro Med Services...
