The cycle starts, dispenses soap, the drum turns several times and then there are 5 beeps and the display flashes F then H and contines to flash them in succession. I have never had a problem with the washer or dryer at all. Please Help!
THE ERROR MESSAGE IS dLF THE WASHER WILL CLICK 4 TO 5 TIMES THEN IT WILL BEEP AND DISPLAY THE ERROR CODE. WHAT DOES THIS MEAN??
Posted on Sep 08, 2008
The following link explains the "FH" error and recommendations you should take:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Eliminate the easy possibilites, first. Make sure you don't have a siphoning issue and make sure the drain pump is not clogged. Listen carefully, when the washer fills and make sure you have sufficient water entering the wash tub. These washer only use about 5 to 7 gallons of water per load, but you should still be able to see and hear water entering the tub. If you have an insufficient amount of water, you may want to inspect the water inlet valve for sediment build up. If you live in an area that has hard water and/or use well water, you could likely have sediment or rust deposits clogging your water inlet valve. A good cleaning with distilled vinegar does a good job at getting rid of deposits.
If these preliminary checks don't do the job, unplug the washer for at least 30 minutes. This is recommended by the manufacturer to reset the main computer. In many cases, this procedure will clear common glitches and error codes.
I hope you find this information helpful. Let me know if you are still experiencing problems and I will assist you further.
Nov 25, 2017 | Whirlpool Washing Machines
Jan 25, 2016 | Whirlpool Washing Machines
Sep 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Apr 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Jul 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
479 people viewed this question
