Question about Nikon Coolpix 5700 Digital Camera
Suddenly stopped working
Screen is light sensitive but blank...cannot play back by slideing button but was successful by other method. lens moves in and out with exposure but no image. data sahows on top and also where you would normally view image. camera is 1 year old. Ray
  • 64 Answers
Hi try with a new battery You might try using a new, clean memory card to see if the problem goes away. If it doesn't, it's most likely a processor or main board failure. windman
Posted on Feb 06, 2006
I replaced the bulb, works fine but now there is no light projection to view slides what do I need to replace?
It definitely has a lens in it then? Kids take them out to play with them and they are pretty useful as a magnifying glass.
If the projection bulb works and there is a lens in it, the only thing it can be is the shutter that comes across the lens to blackout the screen as the slide is changing. As the carousel starts to move, the shutter comes across, the old slide is removed, the new one inserted and then the shutter retracts to show that slide on the screen.
How you get to it and what is likely to be wrong with it, I am not sure, a linkage come off it or something similar?
Jan 24, 2016 | Kodak Carousel 4600 Slide Projector
Canon PowerShot S2IS Digital Camera
Try to remove the battery for an hour, & put it back again..
Let me know..
May 29, 2008 | Canon PowerShot S2 IS Digital Camera
Mintek MDP-1760
Does it have a lock button like an Ipod? A small awitch somewhere that disables all controls? You might also check the poinjt where the AC/DC adapter plugs in, there may be a switch that chooses the battery or input power.
Feb 22, 2008 | Mintek MDP-1760 Portable DVD Player
How do i fix my ipod
Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. b> Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. b> iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact.
iPod into Diagnostic Mode
http://www.methodshop.com/gadgets/ipodsupport/diagnosticmode/index.shtml
Apr 18, 2013 | Apple Audio Players & Recorders
How can i restart the ipod
How to Reset Your iPod b> Toggle the "Hold" switch to the "On" position, then "Off." The "Hold" switch is the small sliding switch on the top of the iPod. Move it to the "On" position to show an orange rectangle. Move it back to the "Off" position to show a white rectangle. Hold the "Menu" and "Center" buttons. Press the 2 buttons at the same time for between 8 and 10 seconds. Your screen will go blank and then boot up with a dark Apple icon. The icon eventually turns bright and brings you back to your main menu once the reset is complete. Check your iPod to make sure it plays properly. If the iPod still does not work repeat the reset process. b> Scroll Wheel and Touch Wheel iPods Move the "Hold" switch from "On" to "Off." Press the "Play/Pause" button and the "Menu" button at the same time. Press both buttons together for approximately 6 to 8 seconds. This initiates the self-running reset process. Make sure the reset was successful. If problems persist you may need to perform the reset process once again. b> iPod Nano Move the on-off switch to the "Off" position that shows the green strip. Leave the iPod Nano in this position for 5 seconds. Move the switch back to the "On" position. Use your iPod Nano to make sure the reset worked properly and all your music is intact. Hope this helps
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
Reset i pod
iPod Nano
Hope this helps
Oct 22, 2012 | Audio Players & Recorders
Blank LCD screen
Check your manual, page 141: Image Review. Should be set to ON (default is OFF).
Sep 01, 2008 | Nikon D200 Digital Camera with 18-200mm...
Recording stopped working
Beleive the CCD has stopped responding. A cheap way to verify this is to point an infrared remote towards the lens and press a key. This will usually provoke a response from the camera even if all else fails, barring a bad pickup device...accordianman
Apr 26, 2008 | Canon ZR200 Mini DV Digital Camcorder
Controller problems
Have you gone back and tried that game again? And were you using one (or both) of the two sticks to move in that game, or were you using the directional pad.
The dual shock controllers on the PS2 have a small, easily overlooked button between the two sticks. It has a red light directly above it. If you push that button, the light will switch on and off. When the light is on, you can use the sticks in pressure sensitive mode. For example, if you push the stick a little, your character may walk, but if you push it further in a direction he will run instead. It's used differently in different games. But certain games won't operate unless that feature is either on or off (again, it varies by game).
My guess is that the button was accidentally pressed while you were playing, and suddenly the controller didn't work. But when you switched games, most games will turn the light on when they start up, if they need it, so the problem corrected itself.
-John
Feb 06, 2008 | Sony PlayStation 2 (PS2) Console
Light sensitive buttons not working
I had simmilar problems, re-setting the phone was no help.
I had to replace the flex cable that connects the screen to the main board in the end and phone now works perfectly.
Nick
Jan 29, 2008 | Samsung SGH-U600
Nikon Coolpix 5700 Digital Camera Logo
46 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
