Question about RCA RT2500 System
Intermitent sound I have a problem with my device, the sound is very good but goes down then goes up in all systems like radio, CD, DVD. Can you help me about that problem?
  • 64 Answers
This is a problem in the volume knob try conductor spray on it.....dosent work its in the amplifier and this is out of ur abilities
Posted on Feb 06, 2006
Radio not working
intermitent on and off sounds like a loose connection ,this could have blown fuse at rear of radio , check and replace if blown and make sure all wiring connectors are pushed home fully
Mar 28, 2014 | Mercedes-Benz Cars & Trucks
I bought a valor dvd head unit i have sound when on radio but when i put in a cd or dvd there is no sound when the dvd is in it plays the dvd just no sound or if the cd is in it has the track numbers but...
go into the setup menu of the DVD and see what the "audio" settings are - PCM,digital interface etc.. try and change these and see what happens
Mar 02, 2014 | Car Audio & Video
No sound
More than likely its a lase problem.
Try using a good DVD/CD CLEANING DISC. They are fairly inexpensive at Walmart or Radio Shack, any place that sells electronics should carry them. Cost is around $15.00. Just put it in player like its a movie and let it run. Hope this helps.
Jan 13, 2013 | Magnavox Mrd200 5.1 Channel Home Theater...
2008 cadillac 6 disk dolby dvd/cd sound system will not play or eject disk
Alien is right, pull the Radio Fuse, then put it back in and eject the CD/DVD. Happens to me sometimes with burned DVDs, seems like the player is picky on the CD/DVD media. Rebooting the device (by pulling the fuse) is the only way to eject it.
Dixit
Dec 02, 2012 | Televison & Video
Since I purchased my 2009 dodge journey I have had an issue with my radio/cd player ... sporadically the volume goes out, if I turn it off, and on it comes right back on, but will only stay on for 20...
AUDIO Any diagnosis of the Audio system should begin with the use of the scan tool. For information on the use of the scan tool, refer to the appropriate Diagnostic Service information.
For complete circuit diagrams, refer to the appropriate wiring information.
AUDIO SYSTEM DIAGNOSIS
CONDITION
POSSIBLE CAUSES
CORRECTION
NO AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Amplifier fuse faulty, if equipped. 1. Check and replace fuses, if required. 2. Wiring to amplifier faulty, if equipped. 2. Verify radio on/off input to amplifier and verify battery and ground connections. Repair wiring as necessary. 3. Radio faulty. 3. Refer to appropriate Diagnostic Service Manual. 4. Amplifier faulty, if equipped. 4. Replace amplifier. NO AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speaker(s) faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty.
5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT ALL SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Power/ground wiring to amplifier open or shorted. 1. Repair wiring as necessary. 2. Power/ground wiring open or shorted. 2. Repair wiring as necessary. 3. Amplifier faulty. 3. Replace amplifier. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. POOR AUDIO AT SOME SPEAKERS - RADIO DISPLAY AND CONTROLS ARE OPERATIONAL 1. Wiring faulty between amplifier and speaker. 1. Repair wiring as necessary. 2. Wiring faulty between radio and amplifier. 2. Refer to speaker diagnostics. Repair wiring as necessary. 3. Wiring faulty between radio and speaker. 3. Check wiring for open or short, repair wiring as necessary. 4. Speakers faulty. 4. Refer to speaker diagnostics. 5. Amplifier faulty. 5. Replace amplifier. 6. Radio faulty. 6. Refer to appropriate Diagnostic Service Manual. SOUND DISTORTION (VIBRATION FROM SPEAKER AREA, BUZZING - HUMMING) 1. Door trim panel loose or missing fasteners. 1. Inspect door trim panel and correct as necessary. Replace any missing fasteners. 2. Water shield loose or misaligned. 2. Inspect water shield and adjust as required. 3. Items placed in door trim panel map pockets vibrating or moving from side to side. 3. Remove items from door trim panel. Ensure that vibration is no longer present. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE OPERATIONAL 1. Radio faulty. 1. Refer to appropriate Diagnostic Service Manual. NO RADIO DISPLAY - AUDIO AND CONTROLS ARE NOT OPERATIONAL 1. Fuse faulty. 1. Check radio fuse and Ignition-Off Draw (IOD) fuse in Junction Block (JB). Replace fuses, if required. 2. Radio connector faulty. 2. Check for loose or corroded radio connector. Repair, if required. POOR RADIO RECEPTION WITH KEY IN ACCESSORY OR IGNITION ON POSITION 1. Antenna faulty. 1. Replace the antenna. 2. Radio ground faulty. 2. Check for continuity between radio chassis and a known good ground. There should be continuity. Repair ground, if required. 3. Radio noise suppression faulty. 3. Repair or replace ground strap as necessary. 4. Radio faulty. 4. Refer to appropriate Diagnostic Service Manual. 5. Faulty rear window defogger. 5. Verify that the rear defogger grid is functioning properly, repair as necessary (Refer to 08 - Electrical/Heated Glass - Diagnosis and Testing). NO COMPACT DISC OR DVD OPERATION 1. Faulty CD/DVD. 1. Insert known good CD/DVD and test operation. 2. Foreign material on CD/DVD. 2. Clean CD/DVD and test operation. 3. Condensation on CD/DVD or optics. 3. Allow temperature of vehicle interior to stabilize and test operation. 4. Faulty CD/DVD player. 4. Refer to appropriate Diagnostic Service Manual.
Nov 01, 2017 | 2009 Dodge Journey
Hello my name is Leo, my cd/dvd player sounds skippy when i play a cd But when i copy one to itunes and down load to my Ipod it sounds good. it also sounds good if i play a song from a playlist What...
the disc might have a few scratches or your cd/dvd player might not be getting enough consistent power make the leads are securely connected and are not faulty also you might have a dust build up in your computer
you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Mar 19, 2011 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Everything works, without sound, from the DVD? All my other sound systems are working.
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no 4 for australia
hope this helps
Dec 05, 2010 | NEC ND-3550A-KIT DVD±RW Burner
My BeoSound 4000's sound goes off while playing a
could be the r/c.the remotes are very powerful,take it into the next room and try again.maybe the volume down button on the units keypad is stuck down or faulty.
Jan 14, 2010 | Bang and Olufsen Beosound 4000 Shelf...
Hp pavillion dv9000- cd/dvd rw drive not working
you have to send it back to hp to get it fixed, this is the second time mine had the same problem
May 10, 2009 | HP Pavillion DV9060US Notebook
Play my mp3 in 2006 Nissan Quest?
I was told the in dash radio unit will not play mp3's. as far as the dvd player, if you have the entertainment system i can't say. I do have two solutions for you.
1) the in dash cd player (mine is a 6 disc cd player) will not play mp3's at 128 bit compression, but for some reason or another I burnt an mp3 disc using the 256 bit compression, still smaller than the standard mp3 comparable cd quality, and unknowingly tried it in the cd player. The nissan quest played it. So it sounds as if the cd player is picky about how low quality of an mp3. 128 is a common reasonable quality. However, I was able to squeeze about 15 tracks on a 256 bit mp3 disc.
2) the in car dvd unit. If your unit is of the standard type, under the seat or mounted elswhere in the car, you could replace it. Dvd players sell for around $125.00+ and will play everything under the sun. reconnecting is not the biggest challenge neither.
& 3) You could purchase an additional hardwired device which allows you to plug in any audio device and play the sound through the Nissans sound system. The device into plugs directly into your wiring loom behind your factory radio. The best part is that the nissan system is already set up to receive this device. It will play through the sat1 or sat2 buttons. I searched and purchased the device online.
i had installed that before learning of the mp3 deal.
well good luck.
Sincerely, Flash
Jan 19, 2009 | 2006 Nissan Quest
RCA RT2500 System Logo
57 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
