Question about Westinghouse LTV-40w1 HDC 40.02 in. LCD HDTV
Pink screen I have a picutre but its pink, Is it time to buy a new tv or can this be fixed realatively cheap?
Just unplug and wait a few seconds then plug back in. all fixed. If that doesn't work it needs serious repair.
Posted on Oct 06, 2008
    Problem Solver:
  • 7 Answers
Wht ballance is off u can fix this but u might do more dammage than good u have to go into service mode to set gray scale .
Posted on Dec 23, 2008
Hp pl5060 Plasma TV has no sound or pix. Screen flashing white
I have a seven year Plasma TV HP PL5060. When I turn on the TV, I have sound but no picture, the screen display (power on) is a snowy blue screen and vertical pink stripe. What is causing this problem and how can I fix it cheap. I can afford a TV repair man at this time, because I am laid off from work. Thanks.
Dec 15, 2012 | HP PL5060N 50 in. Plasma HDTV
Distorted picture that curves up at the bottom of the screen
My 9 years old Mitsubishi WS-55857 had the same problem (distorted pictures) for couple of months and I was about to buy a new plasma TV. But, I found TvRepairKits.com and I decided to give a try before buying a new TV. I received a convergence repair kit in two days with web site info for detailed instructions with many picutres to explain the process. When I had questions and Ed was very prompt to answer my questions thru the e-mail. I never done solding before, but I am moderate handy person. I spent less than $100 and three hours and my TV picutre looks stunning. I went thru advanced convergence process after I repalced the convergence chips and replaced RCA video cable with better quality and my TV picture looks as good as brand new. Thansk ED for your help! From Portland Oregon
Feb 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Can u fix an lcd screen, the internal screen is cracked
No,not buy able LCD screen,because LCD Screen is the most expensive in the tv.Tv compannies well not sell them out cheap,only as same as a new tv.
Jan 07, 2010 | Sylvania LC370SL8 37 in. LCD Television
Samsung 46" pink dots
I had a problem with the TV going on and off several times before "warming up" and then having pink dots. I would have to reboot to get rid of the dots. I called 1-800-SAMSUNG and reported that I had problems with the capacitors. That is what was causing the problems - cheap capacitors and Samsung is aware that this has caused many TV's to malfunction. My set was not under warranty but Samsung sent a technician across two state lines to fix my TV. As long as the problem is the capacitors Samsung will cover this service call 100%. My TV is fine now. BTW - capacitors which are sold in Radio Shack are not expensive. Why Samsung chose to put the cheapest Korean capacitors in their expensive TVs is a mystery.
So if your TV need warming up and has pink dots on the screen - call 1-800 -SAMSUNG and tell them your capacitors are malfunctioning.
Nov 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
The colours on my tv have gone pink and green
Either your picture tube has gone bad or the transistor or IC on the crt board, on the picture tube, that feeds the blue gun has gone bad. You would have to test the transistor to see if its shorted or open with a multi-meter, or check the voltages to and out of it. The voltages are around 200v and dangerous if touched, best left to a proffessional. If its the transistor/IC it would be a cheap and easy fix by a repair shop, if its the tube, you may want to go tv shopping.
Aug 30, 2009 | Goodmans W280NS Television
Power button Flashes, tv doesn't turn on
Buy a new one , not worth fixing. I have the same tv, with the same problem . It's getting old now and the price of a new one . It might cost $ 400-500 big ones to fix it . Thats half the price of a new flat screen , cheap model mind you . But I still think it's not worth it .
Nov 28, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Screen problems with HDTV lcd flat panal HP TV
Most likely it'll cost you as much as to buy a new tv.
Jan 20, 2008 | Televison & Video
Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
Jan 01, 2007 | Emerson EWF2703 27" TV
Televison & Video Logo
581 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
