Question about Jenn-Air Refrigerators
Jennair JCD2389GES Ice Maker Problem It Grinds Ice in Cube Postion, get Chrushed Ice in both Chrushed and Cube postion William Hilpert bhilpert2000@yahoo.com
    Genius:
  • 1,269 Answers
Try to do a hard reset. Turn off the unit and unplug the power cable for several hours like 3-4 hours then check if that fixes it.
Posted on Sep 07, 2008
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Jan 23, 2014 | Refrigerators
Ice maker is not making ice. Reset button already pressed
is the chrome lever in ice tray up or down.it should be in the down position.there is a sensor that turns off when in the up postion
Feb 14, 2013 | Refrigerators
Have a jennair refrigerator mdl#jfi2589aes took the ice cube storage box out to fill cooler, when i put it back in the ice cube maker will not dispense ice cubes to the storage box, ice maker is making...
Hi
This usually is because the drive on the ice box is not engaged,
1. Remove the ice box and empty it into a bowl
2. Replace the ice box and turn the auger (spiral metal inside) until it locks into the drive motor
3. Ensure the box is pushed back as far as it will go
4. Put ice back into ice box
5 Try dispensing ice again
This is a common problem as there are teeth on the back of the ice box that have to align with the drive motor in the back of the freezer
Hope this helps
Gordon
Apr 22, 2011 | Jenn-Air Refrigerators
Ice cube maker does not work what can be the poblem
first of all assure that u are getting water inside of the tray of the ice maker if you have no water then u will want to ceck in the back of the unit down the bottom a blue or white plastic piece this is called the water valve assure that u are getting water through the tube into the icemaker sometimes on some units there willbe a freeze up in the line if this is the case then you would have to defrost the line itself if your unit is getting water and u can feel ice on the inside remove the entire icemaker unit and run hot water to remove all frozen ice then reinstall your doing this becasue sometimes the gear cannot turn becuase it comes out of postion and sometimes this does make the gear go back to normal after u install you would have to wait till your icemaker once again reaches 30 degrees and then it would start making ice again if it doesnt not make ice at this point then u would have to buy a new ice maker cheapest way ton get a new icemaker is through marcone appliance parts and they will ship it to your door hope this helps
Jul 18, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice Maker
move arm to down postion. defrost and clean ice maker, ice jam
Sep 08, 2009 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Cube ice button lit up but only dispenses shaved!?
In the back of the freezer behind the ice bucket you will find a switch that goes up and down, chances are it is either stuck in the up postion or the lever on the bucket is in the wrong location
Aug 11, 2009 | Frigidaire Refrigerators
JCD2389GES
hi thanks for the question the first thing you said i would think the water valve but then you said the ice did not eject so i would think the ice maker is the problem thanks the appliance doc
Apr 13, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker constantly runs
You do not have the actuator postioned correctly on the switch inside the door. The lever has to press up against the switch when you push it. Re-postion the lever.
Apr 11, 2008 | Frigidaire PLRS267ZAB Side by Side...
Ice Maker Making Noise
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
Nov 06, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
194 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
