Question about Microsoft Windows XP Professional
All short cut key to operate the exl.
I dont know any short key in exl. I mean , how to complete the any type of work in exl. speedily? I can operate the exl. but it is only for rutine. So I want to know more about exl. Pl. help me & obliged.
  • 53 Answers
Hello.
Enter here: Click
Posted on Sep 07, 2008
  • Turkel A Sep 07, 2008
    Sorry link is here:
    www.usd.edu/trio/tut/excel
I have a 96 Pontiac grand am we 2.4L twin cam the anti theft system kicked on but I followed the steps and reset it then it started coming back on reset ran fine then just one day bam died not like running...
the lamps you need to watch the lamps. they don't lie.
so now it dont start (but cranks)
the operators guide tells you what the lights mean, lost that.?
2 lamps are security or IMMOBILIZers have a lamp
  • off means OK
  • on means its bad ( locked out, )
  • flashing means that system is sick.
generally. got both lamps? look carefully.
IMMO kills engine, if car is tired to start. with wrong key. (and or fob)
security is theft alarm. and some cut spark others cut fuel other cut
some even cut cranking,
does yours crank?
or cranks ok but wont start.
no matter the lamps are FIRST> never last. never replace parts until you know what the lamps mean.
see this?
http://newrockies.com/5232/need-know-gm-passkey-security-systems/
Passlock: System must detect proper R-code within ignition lock (or ignition switch) in order to start engine. Does NOT have chip in key.
look at the lamp, and do not dis believe it,
Jun 25, 2014 | Cars & Trucks
Webcam are not working
In windows 7 you dont need to install it will install automatically an it wont shows any short cut, when you use skype or other messenger for video chat the camera activate itself. If you want to use the cam without messenger than you need to install any type of camera software like CyberCam, etc
Mar 23, 2014 | Computers & Internet
Fan only works high speed
witch fan are you meaning engine fan or heating fan (blower) engine fan there thermostat switch on the radiator may need changing. if engine is at red line and then it come on. heater there is a regulator for the fan in the dash at the back of the blower system that may need changing. dont know what year or model you have so could not say how to ge to it the best way.
Sep 24, 2013 | Volkswagen Polo Cars & Trucks
How to format my internal memory for my p990i
There is also a secret code to format ur hard disk, I stumbled upon it few days back. :-) Assuming u've flip closed mode, press the right short cut key once, then press *, then press left short cut key twice followed by * again, then again press left short cut and * again. U would now get a sevice menu, go to the last option and u are there...!! :-) google about P990i hidden menu, if u arent clear what key to press. :-)
Jun 02, 2009 | Sony Ericsson P990i Cell Phone
A13 sign the dash
The 15% is a warning the oil change is near, The "A" means change oil only ("B" would mean change oil and filter) The 1 means to rotate the tires, The 3 means to change the trans fluid. The owner's manual has the complete chart.
Apr 28, 2009 | 2005 Honda Odyssey
I accidentally hit something while I was typing on msn to make the green characters on the keys appear and dont know how to change it back. it only seems to be doing on msn and not on here though. can you...
Your font is green only on msn. Go into msn log on and you have to go in to options and change the font color. It was probably a short cut key stroke you hit. If not you browsers is the problem
Aug 28, 2008 | Acer Computers & Internet
Procedure to replace rear bearing (outer)
1- remove the wheel.
2-remove the drum brake if it is tight relece the hand brake also loose brake adjusment.
3- remove brake pipe and hand brake connections.
4-on the back you can see 4nuts where barke housing fitted to the exle.
5- dont remove brake shoes.
6-pull the housing from the exle .
after all that remove the housing carefully hold your two hand both sides now you get out all assemply put on the work bench you need specila puller to remove the bearing the brearing is in the back look the front side of the drave shaft the end of the brake housing.
when you remove the old one put new one use the hydrolic pressure.
check the oil seal the end of the exle.
Aug 12, 2008 | 1985 Toyota Pickup
EXCEL ALL SHORT FORMULA
hiiiiiii
u know vlookup function,then piviot table
u know na tell short formula
genious...
Dec 14, 2007 | Microsoft Excel for PC
Microsoft Windows XP Professional Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
