Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Not working My chamberlain garage door opener stop working, I press the button and it does not open or close, all it does is make this clicking noise and nothing is in the way of the sensors for the door to go up and down. I have a chamberlain lift master formula one model 2280r. It does nothing, I push the button and all it does is make a thump and then nothing. I have used this side of my garage maybe 10 times. There is also nothing blocking the sensors. one day it opened fine and would not shut again. The gears look brand new and the belt is not worn. I have not idea what to do?????
  • atmiller Jan 04, 2009
    Chamberlain told me to replace the logic board. I did, and nothing was fixed. Now I'm out $70 and nothing is solved.
  • Kaz Masri
    Kaz Masri May 11, 2010
    How old is this unit ?
  • 504 Answers
IT MAY BE AGAINST THE TRAVEL LIMITER BOLT.
IF IT IS YOU WILL NEED TO UNPLUG THE UNIT REMOVE THE COVER AND TURN THE MOTOR BY HAND TO BACK OFF THE PRESSURE.
MAKE SURE YOU GO PAST THE LIMIT SWITCH.
ADJUST THE LIMIT SO TH DOOR DOES NOT HIT THE BOLT.
HOPE THIS HELPS
Posted on Jun 11, 2010
With my door closed, i push door button to open and the chain and opener continues inthe closing mode. any help?
Shop for sears craftsman liftmaste... on Google
Garage Door Opener Gear...
$31.45
Sears Parts D... Liftmaster 41C4220A Ge...
$21.75
Preferred Do... Chamberlain/l... Sprocket, Gea...
$17.95
eBay Direct Replacement f...
$20.95
Moving Up G... Liftmaster 41c4220a gea...
$31.67
North Shore... Search Results
    Liftmaster Gear And Sprocket Kit 41c4220a Chamberlain ...
    www.sears.com/search=liftmaster%20gear%20and%20sprocket%20...
    Searsmore info. + -. Chamberlain LiftMaster 41C4220A Gear & Sprocket Assembly Kit. $31.40 ... Chamberlain Sears Craftsman Liftmaster 41A2817 Gear Kit. $27.65 ...
Jan 10, 2016 | Sears Craftsman LiftMaster Chamberlain...
Why won't Chamberlain 1040-6 garage door opener open or close?
In addition to the ANT suggestion, are you able to open/close the door with the button first? And then check the 12-volt battery in the remote control.
Work-around: Modern cars have the ability to learn the motor's code. Then I use the built-in openers on my cars to open the garage door as work-around. All you have to do is initiate the learning process by pressing a button on the motor, and then keep pressing your built-in opener's button until the light becomes steady. Try to let your car stay as close to the motor as possible.
Apr 27, 2014 | liftmaster Chamberlain Garage Door Opener...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
My liftmaster will open with the remote but to close the door, we have to hold down the wall unit. It starts to close, jerks to a stop, then we have to press and hole the button and it closes.
Hi, it is probably the safety photo beams out of alignment or not working, when this happens the garage opener goes into 'dead man' operating mode, ie you need to keep the button pressed for the door to operate. You can find user and installation manuals here - Liftmaster Garage Door Opener Installation Manuals
Sep 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain model 1100 wont close
I WOULD TRY DOWNLOADING THE MANUAL AT http://www.chamberlain-diy.com/pdfdocs/114A1902.PDF
IS THE UNIT STUCK AGAINST THE STOP BOLT ON THE RAIL??
IF IT IS THE INSTRUCTIONS TELL YOU HOW TO RELEASE IT.
HOPE THIS IS HELPFULL
Mar 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Not working
clicking noise usually is from relays on logic board. you over-heated unit. wait 25 monutes for motor to cool.
Aug 02, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
793 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
