Monitor goes into sleep mode
Computer monitor goes into sleep mode
  • Anonymous Jan 03, 2009
    Can cant even get my new a6567c PC set up. I brought it home and there are NO instructions. Just a sheet of pictures. I suppose they all think we're idiots and need pictures to figure things out?
  • charlottemoo Mar 06, 2009
    my monitor goes to sleep
How do you go into the control panel when the monitor won't get out of sleep mode???
Posted on Feb 20, 2010
I DONT KNOW BUT MY GRANDMOTHER IN LAWS COMPUTER IS DOING THE SAME AND CHANGING IT IN THE SETTINGS DOES NOTHING!!
Posted on Dec 29, 2009
  • 258 Answers
You can change this by going to control panel then display icon and changing it in settings.
Posted on Sep 08, 2008
4 Suggested Answers
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 25, 2008
rcirone203
  • 70 Answers
SOURCE: Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Posted on Oct 26, 2009
john_1983
  • 6 Answers
SOURCE: Need help monitor stays in sleep mode... :(
Goto your Control Panel > Hardware and Sound > Power Options...
You can change or disable Sleep and Hibernation settings there.
Posted on Oct 01, 2011
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
HP LE1901w -- monitor starts then goes into sleep mode
welcome my friends ,, all about football here !
http://www.news-football.org/ Football News
diego goals vs barcelone ! here ! Football News
Apr 24, 2010 | HP w1907 LCD Monitor
Monitor works fine until the sleep mode and then it goes blank. I have to unplug the power button and it does work again
It seems it is a motherboard battery problem. It most likely is not the monitor which is in "sleep mode", it is the computer itself.
When you cannot get a computer out of "sleep mode" by any other means, typically the cause is that the button-cell-type battery of your computer, which is located on the motherboard, is empty. When your computer detects this battery is empty, it goes into a low-power mode. The solution is to replace the button-cell battery on the motherboard of your computer
If this solution works fine for you please rate this
Feb 24, 2010 | Dell E196FP 19" LCD Monitor
Monitor goes into sleep mode and won't come back
go through control panel to Power Options, switch off the options to sleep/hibernate.
Oct 27, 2009 | Computers & Internet
Why does my monitor say "no signal" when you try to us my computer after it has been on sleep mode?
The computer turns off the signal to the monitor after it goes into sleep mode. You can adjust the power settings in the computer to not turn off the monitor.
Sep 21, 2009 | Acer X193W LCD Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
I have a LCD panel it is connect to to the LCD. I need to change a setting on the computer to make it stop going into sleep mode, however, now that it's in sleep mode, how do I get out of that so I can make the change?
Jan 09, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor goes to sleep and won't wake up
Yeah, im not sure about how to fix the problem with it shutting down like that, but one option is to go under your control panel and taking off the sleep function, or putting it on a 4 hour timer so that doesnt go into sleep mode anymore. However, the problem is not your monitor but your computer. Id just take the sleep mode off, there is no need to have it on.
Dec 24, 2007 | Computers & Internet
Computers & Internet Logo
1,169 people viewed this question
David Payne
David Payne
