Question about GPS
Format 4gb sandisk sdhc card to be compatible with tom tom go 510
  1. Format the card in your PC's card reader as Fat32
  2. Insert the card in your TT, turn on your TT, connect your TT to your PC, and from your PC find the drive letter that corresponds to your SDHC card
  3. Now format the card in your TomTom using Windows - don't worry if it formats to a lower capacity.
  4. Turn off your TT, remove the card, place in your card reader
  5. Format your card using "Quick Format"
Posted on Feb 12, 2010
Sdhc unable to format write protected
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Also, make sure the device in which you're trying to format the card is SDHC-compatible.
Jan 28, 2013 | SanDisk Extreme Hd Video Sd Sdhc 4gb...
My computer wont format my micro sd card
Is it an SD card or a microSD card? If it's a 4GB (or larger) card then it's neither, but instead an SDHC or a microSDHC.
If the card is an SDHC/microSDHC then your card reader may be only SD-compatible. If this is the case then you can buy an SDHC-compatible card reader and use that. Alternatively, if you want to use this card with some other device, such as a camera or a phone, format the card in that device instead of in your computer.
Jul 10, 2012 | SanDisk 4gb Class 4 Sdhc Sd Hc Flash...
Cannot format 8gb sandisk sd card
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Feb 04, 2011 | HP Photosmart 735 Digital Camera
4GB Sandisk is write protected; I don't know what I pushed to do that, but now I need to unlock it so I can use my camera. Please help
On the side of the SDHC memory card is a sliding lock I have a diagram to show where this is and which direction to push the slider. Here is the diagram.
Also to make the SDHC work compatible with your camera you need to format the memory card. Each time you download the picture files the memory card needs to be formatted, never format in the computer and expect the card to work in the camera.
Dec 27, 2010 | SanDisk 4 GB Standard SDHC Card with Rezo...
It will not format a 4gb SanDisk SD card
Your 4GB card is actually an SDHC card. The DX6490 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with SD cards 2GB and smaller.
Nov 28, 2010 | Kodak EasyShare DX6490 Digital Camera
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
When I add a sandisk 4gb card to the camera it says card full. Is 4gb to big for a dc59?
A 4Gb card will be an SDHC card. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 21, 2010 | Rokinon DC59 Digital Camera
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
Cannot transfer photos to XP from SDHC Ultra II Card
Took it to Jessops by the process of elimination "Integral reader faulty."
What a waste of many hours !
Feb 02, 2009 | SanDisk Ultra II 4GB Memory Stick PRO Duo...
Card Error on a 4GB SDHC Sandisk Memory Card
I went onto the BestBuys site and found a link for compatible memory cards - The SanDisk SDHC isn't compatible with the Canon Poswershot SD750!! Only a 2GB card will work. The Lexar SD and the Kingston Technology 2GB will.
Dec 19, 2007 | SanDisk 4GB Secure Digital High Capacity...
GPS Logo
827 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
