Question about Texas Instruments TI-84 Plus Calculator
Calculator My calculator works but will not print on tape. I need a printout in my occupation>
  • Anonymous Nov 11, 2008
    If you connect to TI Connect while you are working on your TI, you can capture a screenshot and then paste it into a word document. You can also use a Virtual TI Calculator but you have to search online and find the ROM for it. Once installed it works great and then you can copy the screenshot. You can also purchase a copy of Smartview which is great for what you are looking for....No I am not a sales rep.
  • Texas Instru... Master
  • 7,993 Answers
You can capture the calculator screen and send it to the computer. From the computer you may able to print it.
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and Click OK..
When the connection between calculator and computer is established, you click Screen capture and the image appeares in the TIconnect window. save the image in jpeg or png format. By default Ticonnect saves images in folder My TiData.
Hope it helps.
Hope it helps
Posted on Sep 19, 2009
Order tape for printing
Lorena, Staples will have it in stock, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Calculator Plain Paper 2 25 150 Pack of 3 Calculator And Cash...
Canon 1904B001AA P23 DH Printing Calculator Staples
How to Load Paper Into Canon P23 DH eHow
Mar 05, 2016 | Canon P23-DHV Calculator
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
E appear on screen, number keys not working.what should I do.
Customer Reviews: Canon MP11DX Printing Calculator
www.amazon.com/Canon...Calculator/.../B0006HWF...
Amazon.com, Inc.The keys (i.e., numbers) get stuck almost every time I use it. I have to actually wiggle the numbers so I can enter the next number. It's not the tape on the ribbon; ...
3 Using your calculator for fractions - The Open University
www.open.edu/...calculator/content-section...
United States Open UniversityMay 3, 2012 - Early Years · Working with Young People .... 11 Natural logarithms and powers of e on your calculator ... The figure shows the display on a calculator screen.... If your calculator is not in Math mode, repeat the steps of Activity 1. ... arrow keysto move between the boxes when inputting the mixed number.
[PDF]Canon MP270 series / MP250 series On-screen Manual
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Jul 17, 2010 | Canon P23-DH Calculator
How to record to a memory card without a computer.this is what i would like to do.is posible to build some kind of electronic circuit that will allow me to record number(or data) to a memory card right...
Yes, it's possible. In fact, it's been done. But unless you want to do a LOT of breadboarding, why don't you just go out and buy an HP 50g calculator, which already has an SD card slot? And if you also want the ability to print to a paper tape, the HP 50g can do that, as well, by connecting to a variety of printers.
Nov 11, 2009 | Sharp EL-1801P Calculator
Monroe Calculator 7130 - won't print red for negative
turn it off & back on & that should fix it. the ribbon lift needs to reset.
dennis
Nov 18, 2008 | Monroe 7130 Calculator
POSSESSED 10 KEY CALCULATOR- DONT LAUGH!
your printer needs some mechnical adjustement for the print wheel and gear train by qualified service technician.
Feb 27, 2008 | Victor 1280-6 Calculator
Calculator print problem
try to move switch into p. or print position
Jan 24, 2008 | Office Equipment & Supplies
Printing on tape
The print cartridge may be installed wrong or there may be a problem with the tape installation, or a part broken on the printer.All these factors can cause no printing
Jan 24, 2008 | Canon MP-11DX Calculator
Texas Instruments TI-84 Plus Calculator Logo
143 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
