Question about Maytag Washing Machines
How to change the belts on a LA712 Maytag washer
Tell me how to get a service manual, Manual!
Anybody know where to get them or find them on the web?
Have a La712 that will not shut off the cold water whether the machine is running or not.
Posted on Sep 17, 2008
Is this an LSE series Washer/Dryer?
The two units are separate, joined only by a plug and socket at the rear of the washer. There maybe Sellotape on the sides of the washer holding it onto the dryer legs, this was part of the transportation protection, just cut it off.
Disconnect the power, Disconnect the plug and socket.
Pull the washer forward until you can tilt it back to rest on the bottom section of the dryer. The belts are accessible underneath the washer unit.
BUT.. Why do you want to change the belts??
Apr 06, 2017 | Maytag Washing Machines
Maytag LA712
irrelevant with no question
Feb 17, 2017 | Maytag Washing Machines
Red fluid leak in maytag washer la712
Sounds like gear case oil. Dark Red? Did you tip the washer over?
Sep 03, 2012 | Maytag Washing Machines
I have a maytag top load washer the washer will drain but will not spin
Maytag washers have two belts one for turning the pump and the other for making it spin. Sounds like the belt for the spin needs to be replaced. It is something that you can do. Maytag washer belts are quite easy to change. Hope this helpedd. Thank you for using Fix ya.
Jun 26, 2011 | Maytag Washing Machines
I have an old maytag model #LA712 top loader. Recently it has started overflowing not stopping when it's filling. This does not happen everytime and it does not leak any other times but when it does what a...
Usually this is caused by the water inlet valve sticking in the open position. If you can catch the washer while it's overflowing, unplug the washer. If the water stops, then the problem is most likely a pressure switch or pressure hose. If the water does not stop, it is most likely the water inlet valve.
May 25, 2010 | Maytag Washing Machines
Washer has a burning smell and will not drain
the burning you smell is probably your belt. if you change the belt and it still has this problem then your transmition has failed. This is a very comon problem with maytag washers.
Apr 24, 2010 | Maytag PAV2300 Top Load Washer
Maytag Washer LA712 spin cycle question
Remove the front panel (2 screws bottom front) and then put the machine into the spin cycle. Be VERY carefful as the transmission also spins and can really injure you if you get to close. Observe the speed in the spin cycle. Then grab the plastic motor cover and gently pull the motor toward the outside corner. If the spin speed increases then you have a problem with either the 2 springs or 4 rollers inside the floating motor mount. See this link The Matag part number that would be the ideal fix is 2-5000. To change the rollers you must remove the pulley and motor mount.
The springs are Item 18. You may have to explain to any parts center what rollers you want.
Jan 12, 2010 | Indesit W 123 Front Load Washer
Model LA712 washing machine has a small leak how
These washers are notorious for getting an injection bladder leak. The baldder is located atop the washer in the imlet hose assembly; here is the part:
Located here on top left hand rear corner:
Remove the injector(white pointed plastic looking thingy) from inside the old bladder and shove it up into the new bladder ; reinstall it back where it came from.
Oct 21, 2009 | Washing Machines
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
Hope this helps
Sep 29, 2009 | Maytag Dryers
How do I take the front cover off a Maytag MAV4755AWW washer to change the belt for spinning the drum?
Although I'm not familiar with that particular model, most Maytag washers have the belts under the washer (no need to remove the front panel) --- just tip the washer back and check to see if the belts are underneath.
Jun 22, 2008 | Maytag Washing Machines
Open Questions:
Washing Machines Logo
247 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
