Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby G3 Why is my Kirby G3 Blowing air and not sucking?
Take the front of the kirby off (the part that has the brush roller in it) and look in the big hole where the fan impeller is. Most likely this plastic part is cracked and needs to be replaced. Just turn the metal rod sticking out of the hole and the outer ring with the fan blades on it will be cracked off of the inner piece. It is a cheap part (usually $12-$15) but getting to it is not for the mechanically disadvantaged.
Posted on Nov 03, 2008
  • 120 Answers
Its probably clogged change the bag, you can also remove the cloth bag unit by holding on the bottom of it and pulling the large end away from the machine to see if theres any thing stuck in the bag tube and the hole that it sits on also check the brush area as well
Posted on Sep 25, 2008
Kirby G3 vacuum shampooer is not picking up water.
Belt may be slipping or wore out. Are you running the brush too low to the carpet. That will prevent it to work.also you have to take the cap off the container when sucking the water up.
Sep 01, 2016 | Kirby Vacuums
Not sucking
belt is not connect to the drive pulley, see manual for fitting or see utube for video
Aug 31, 2012 | Kirby Generation 3 Bagged Upright Vacuum
My Kirby is blowing out not sucking in how do I change this?
Either there is a blower option on the vacuum cleaner that needs to be set back to where it belongs, or somebody changed the brushes on the motor and got the brush or field wire connections reversed (one or the other, but not both).
Oct 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Spray gun for cleaning--Do you just hook it up to the regular hose? How do you avoid it sucking?
yes it goes on the hose but it goes to the blower outlet there is 2 ports in a kirby one sucks and the other is the blower place hand over one you feel air blowing out that is where you attach the hose
Dec 18, 2009 | Kirby Heritage II Vacuum
No suction generation 3
there is a clog in the line try blowing it out with compressed air
Jun 27, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby blowing out aire
Unplug the vacuum and clean out the hose that goes from the beater to the intake. The hose is either plugged with debis or has become disconnected or BOTH. You may have to use a screw driver to remove the plate over the beater brush.
Mar 08, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
139 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
