Iolo Technologies System Mechanic: Windows Logo
Posted on Aug 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Program hangs at launch. Registry cleaned; jscript.dll registered; SM deleted and all traces removed from computer. Software reloaded - same problems.... No other problems with computer ord other software...
Anonymous
Level 2:
Novelist:
Scholar:
  • Expert 105 Answers
  • Posted on Oct 07, 2011
Anonymous
Expert
Level 2:
Novelist:
Scholar:
Answers
105
Questions
0
Helped
23389
Points
117
If you have done all this as a final step you may uninstall and re-install the software and check . That should work well for you
Any doubts you can get the help of a certified technician through the website:
www.thebestpcdoctor.com
Toll Free: 877 407 9229
2answers
Fix my vb script engine on my computer / Windows 7
Fix Windows Script Host If you are experiencing script host issues, you might notice error messages such as "Library not registered." Script host issues occur when scripting components do not exist in the Windows registry, according to Microsoft. Your version of Windows determines how the missing scripting components affect your system. You can repair script host problems by using your PC's native features.
Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" regsvr32 %systemroot%\system32\vbscript.dll regsvr32 %systemroot%\system32\jscript.dll regsvr32 %systemroot%\system32\dispex.dll regsvr32 %systemroot%\system32\scrobj.dll regsvr32 %systemroot%\system32\scrrun.dll regsvr32 %systemroot%\system32\wshext.dll regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt. b> Register Components on 64-bit Systems b> Press the "Windows" key. Type "cmd" in the dialog box and press "Enter." This will open the Command Prompt. Type the following commands at the prompt one at a time and press "Enter:" %systemroot%\system32\regsvr32 %systemroot%\system32\vbscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\jscript.dll %systemroot%\system32\regsvr32 %systemroot%\system32\dispex.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrobj.dll %systemroot%\system32\regsvr32 %systemroot%\system32\scrrun.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshext.dll %systemroot%\system32\regsvr32 %systemroot%\system32\wshom.ocx Exit the Command Prompt.
Enable Windows Script Host b> Windows Script Host is an administration tool by Microsoft that creates an environment for hosting scripts. According to Microsoft, Script Host will manage security and invoke the proper script engine. Script Host comes standard on all Windows operating system versions 98 and later. Therefore, you can easily enable Script Host on your computer. Go to the Windows Desktop. Click on the "Start" button. Select "Run" from the menu of options and icons that opens. Type the word "regedit" into the text box of the Run window and then click "OK." The Registry Editor window will appear. Select "HKEY_CURRENT_USER\Software\Microsoft\Windows Script Host\Settings" from the folders on the left of the Registry Editor window. Double click on "Enabled" in the window pane to the right. Set the Value to 1. Return to the folders list in the Registry Editor. Select the folder "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Script Host\Settings." Again double click on "Enabled" in the window pane to the right and set the value to 1. That's it, you have successfully enabled Windows Script Host.
10helpful
3answers
How to install msvcp90.dll
hi,
http://www.fix-all-dll-errors.com/msvcp90.dll/
u can go to this site...this will help in case of missing or for downloading dll's or also if there is errors in dll's..!
I also registered few dll's from this site...worked in my case :)
4helpful
3answers
Windows XP boot after an error, it can not find the file shfolder.dll, and is included in the Windows folder. What do I do?
http://www.fix-all-dll-errors.com/shfolder.dll/
This will fix the issue without any botheration.find that dll here :)
Regsvr32 jscript.dll is deleted
Method 1: Reregister Jscript.dll
  1. Click Start, and then click Run.
  2. In the Open box, type regsvr32 jscript.dll, and then click OK.
  3. Click OK.
If the file does not register as expected, or if you receive an error message, the system file may be missing or damaged. To extract the missing file in Windows XP, follow these steps:
  2. In the Open box, type msconfig, and then click OK.
  3. Click Expand File.
  4. In the File to restore box, type the name of the file that you want to restore.
  5. In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or click Browse From to locate the Windows XP .cab file.
    Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
  6. In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
  7. Click Expand.
  8. In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
Open a dialog box that previously experienced the issue that is described in the "Symptoms" section of this article. If the issue recurs, go to the next method. uparrow.gifBack to the top Method 2: Edit the registryTo do this, follow these steps.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
  2. In the Open box, type regedit, and then click OK.
  3. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c260-6ac0-11cf-b6d1-00aa00bbbb58}\InprocServer32 The (Default) value data should contain the following value: C:\WINDOWS\SYSTEM32\JSCRIPT.DLL If it does not, double-click Default, type C:\WINDOWS\SYSTEM32\JSCRIPT.DLL in the Value data box, and then click OK.
  4. The ThreadingModel value data should contain the following value: Both If it does not, double-click ThreadingModel, and then type Both in the Value data box.
  5. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c261-6ac0-11cf-b6d1-00aa00bbbb58}\InprocServer32
  6. Repeat steps 3 and 4 to edit this key, and then go to step 7.
  7. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\CLASSES\CLSID\{f414c262-6ac0-11cf-b6d1-00aa00bbbb58}\InprocServer32
  8. Repeat steps 3 and 4 to edit this key, and then go to step 9.
  9. Exit Registry Editor.
Problem with Zoombrowser EX Digital Camera software. I've downloaded Zoombrowser EX to my computer...disk from Canon camera purchase. When I click on the icon, I get "class not registered". Some...
This is a registry error. Try this: type regsvr32 quartz.dll in the run box on your computer. That would be: Click start, run, and then type this into the box.
If yoou do this correctly, you should see a message that it was registered correctly.
Try the program to see if it fixed the issue.
System Mechanic causes Registry problems
I use nCleaner and have had absolutely no problems for over a year now. I find System Mechanic has too large a 'footprint' and, like you said, is pretty incomprehensible to use out of the box.
The only thing that took me unaware with nCleaner was that it cleaned out My Received Files by default, so all the photos I had been mailed through Messenger were deleted, so make sure you copy them into another folder first :)
I have never had any software problems after using it though, and I install and uninstall programs pretty regularly!
So it comes highly recommended. It's a bit like CCleaner (if you have heard of that) but with more functions like Registry Clean.
I would reinstall XP first though as SM seems to have messed up, and you want a clean start. Also remember to reinstall all the XP drivers for your motherboard too.
Hope this helps
Chris (ziraffa)
2answers
I can't defrag and DLL initialization failed message.
Run a free Registry scan will fixed DLL problem.
So, download a free registry cleaner and install the software. The free registry cleaner software automatically scans the registry, cleans it up, backs up the data for you to restore if you encounter any problem after you have cleaned the registry. The registry cleaner can also configure a startup organizer and remove embedded keys that are used by malware like Trojan, virus, dialers and so on. Registry cleaner software also eliminates the free spaces within the registry and traces of programs that are never completely uninstalled. In short registry cleaners are truly effective tool for safe and faster computing. So get it now!
How to remove manually Malwarrior rootkit malaware please help
Sir,
Manual removal of any spyware can be difficult. When you try to manually remove MalWarrior 2007, you risk destroying your PC. It’s highly recommended you use an automatic spyware scanner to determine you’re infected with MalWarrior 2007. It’s also recommended you backup your system any time before editing your registry.
Your Windows registry is the core of your Windows operating system, storing information about user settings, system preferences, and software, including which applications automatically launch at start up. Because of this, spyware, malware, and adware will often bury their own files into your Windows registry so that they automatically launch every time your start up your PC.
Because your registry is such a key piece of your Windows system, you should always backup your registry before you make any changes to it. Editing your registry can be intimidating if you’re not a computer expert, and when you change or a delete a critical registry key or registry value, there’s a chance you may need to reinstall your entire Windows operating system. Make sure your backup your registry before editing it.
  1. Select your Windows menu “Start,” and click “Run.” An “Open” field will appear. Type “regedit” and click “OK” to open up your Registry Editor.
  2. Registry Editor will open as a window with two panes. The left side Registry Editor’s window lets you select various registry keys, and the right side displays the registry values of the registry key you select.
  3. To find a registry key, such as any MalWarrior 2007 registry keys, select “Edit,” then select “Find,” and in the search bar type any of MalWarrior 2007’s registry keys.
  4. As soon as MalWarrior 2007 registry key appears, you can delete the MalWarrior 2007 registry key by right-clicking it and selecting “Modify,” then clicking “Delete.”
Computer acting funny after you’ve edited your registry and deleted MalWarrior 2007 registry keys? Just restore your registry with your backup.
How to remove MalWarrior 2007 DLL files: Like most any software, spyware, adware, and malware may also use DLL files. DLL is short for “dynamically linked library,” and MalWarrior 2007 DLL files, like other DLLs, carryout predetermined tasks. To manually delete MalWarrior 2007 DLL files, you’ll use Regsver32, a Windows tool designed to help you remove DLL and other files.
  1. First you’ll locate MalWarrior 2007 DLL files you want to delete. Open your Windows Start menu, then click “Run.” Type “cmd” in Run, and click “OK.”
  2. To change your current directory, type “cd” in the command box, press your “Space” key, and enter the full directory where the MalWarrior 2007 DLL file is located. If you’re not sure if the MalWarrior 2007 DLL file is located in a particular directory, enter “dir” in the command box to display a directory’s contents. To go one directory back, enter “cd ..” in the command box and press “Enter.”
  3. When you’ve located the MalWarrior 2007 DLL file you want to remove, type “regsvr32 /u SampleDLLName.dll” (e.g., “regsvr32 /u jl27script.dll”) and press your “Enter” key.
That’s it. If you want to restore MalWarrior 2007 DLL file you removed, enter “regsvr32 DLLJustDeleted.dll” (e.g., “regsvr32 jl27script.dll”) into your command box, and press your “Enter” key.
Thanks
Good Luck
"Don't forget to rate the solution"
I need to remove norton from this emachine to install trend micro internet security pro how ever it tells me that the specific path not found nplease advise how to remove. thank you ...
First of all I am assuming that you didn't correctly uninstall Norton in the control panel through add and remove programs right? Delete all traces of the program that you can. Do a computer search on your hard drive for "norton". You will see what is left. You will also have some registry keys that need to be removed. I suggest downloading a free program that is great called Ccleaner. Do a regular scan...then do a registry scan. Always backup your registry. Restart your computer and do it again.
Now your norton should be cleared out and you can install your other software suite. You need to make sure that dll's that norton shares are not deleted. Norton is a pain in the **** to get rid of.
Ccleaner also has an uninstall utility that may work just a little better than the windows version.
Make sure you restart. After every software change just in case.
Top Iolo Technologies Computers & Internet Experts
Stan Ford
ELECTRICKSUSA
ELECTRICKSUSA
Are you an Iolo Technologies Computer and Internet Expert? Answer questions, earn points and help others
