Question about Kenmore 46462 Front Load Washer
Washer does not lock
Hey there I have had this washer for less than a year but all of a sudden I tried to put in a load and when I tried to close it something was wrong with the door lock so now it doesn't close. If anyone can help me how to solve this please reply I think the door lock is broken but what should I do but a new door or what. Please help.
  • overdoze760 Sep 07, 2008
    Well I think its the lock that busted inside the washer I am not sure what to do or where I can get the parts everything else runs smooth I need to hold the door close in order to wash I need to stand there 27 minute.
  • 53 Answers
Hello, there little grip on machines door i think you need change it.
Posted on Sep 07, 2008
  • Turkel A Sep 08, 2008
    Contact support center.
Washer won't start and the door is closed tight
Replace the door lock, takes about 10 mins. Just replaced mine. Ordered it from Amazon for less than 40.00. You take the top off and unscrew the lock from the front. Reach in and pull up, unplug old one, plug in new one. put new one back in the holes, screw it in tight. Put the top back on and your done. Don't forget to unplug it before you start.
Sep 21, 2014 | Frigidaire Affinity ATF7000E Front Load...
SD code
Use the rule of thumb that once you have spent have the cost of the old machine on repairs, it is time to replace.
Mar 12, 2017 | Washing Machines
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
We have an LG top load model WF-T7012EN. All of a sudden it would stop and dE message will be displayed. If you try to start it again, the same scenario will happen. We had tried to level the load and...
dE indicates a door lock error. Turn off and then unplug the washer to reset the machine. Press and hold the Start/Pause button button for 5-10 seconds. Connect the power cord. Turn on the washer. Open and close the lid to see if it closes properly. Try to run the washer through a cycle.
On some LG top-loading machines, the error is simple to fix. These LG top loaders used a magnet in the front of the lid that to be in place to trigger the lock. When the magnet breaks off or is misplaced, the dE error will occur. If you find the magnet in the washer, replace it in the lid. If you don't see the magnet, get another one. Keep the magnet in place with duct tape.
On other LG washers, the problem is the door not being aligned with the lock, the lock assembly or the electronic control not getting the lock message. Make sure that the lid is closing properly. Bent hinges can cause the issue. Check the latch assembly and the wiring between the latch and the control board. To check the latch assembly, you may need to remove it from the washer. Check the circuit with a multi-meter to ensure that the switch gets power. Replace either if faulty. If the latch assembly and wiring are good, then the control board may need to be replaced.
I hope this helps.
Jan 12, 2018 | LG Washing Machines
I have a zanussi turbo dry built-in washer/dryer built-in 1200, Mod zjd . 125, and I do not know how to use it. HELP! Thanks, Cindy
Hey, Just load the washer but do not over load. These combo washer dryers are strictly for smaller loads. You should have a drawer to the left that you place the soap and softer and bleach. Set to the washer to washer. The door should lock automatically. Then set your dryer setting to the the Heat temperature that you want. 100 degrees is ok to start with. then it will adjust itself as it goes through the cycles you have set. Enjoy the machine should work. If it does not look to make sure that the door is closed all the way. Sometimes you have to open the door and reset it and shut the door or while it is closed gently push on it till you hear a small clicking noise. ENJOY YOUR WASHER DRYER COMBO
Aug 28, 2009 | Washing Machines
Front load washer ripping and putting holes in clothes!
We are having the same problem too. Have you find a solution yet?
Jun 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Owners manual
Dear Mupin,
ngafam at your service.
I under stand you have this problem!
I have a kelvinator K605 washing machine that has suddenly halved it's wash time! I can't find my user manual.
At the bottom of this page is a web site for Kelvinator manuals from fixya.com.
But I have some most important advice for you to read first!!!!!!!!!!!!!
This machine is very and an energy gussler!
My advice is not to put your good money into bad!
It's not worth spending a dime to repair!
The new machines cost so much less to operate and will pay for them selves in only a few years!
And the new machines will not wear out you clothes so fast! Top load machines used to use 54 gallons a load.
Todays top load Speed Queen washer uses only 34 gallons!
cost only 549 and out lasts every machine on the market.
It's tested at 8 loads a week for 25 years.
has a 3 year warranty compared to the 1 year of all the rest and a TEN YEAR TRANSMISSION WARRANTY, compared to ONE YEAR of all the rest!
Today you can get 10 to 15 years depending how much you spend on the washer!
The washers and dryers today use so much less water,electricity,and detergent that they pay for them selves after a only a few years.
My advise is, do not put good money into a washer that is over 10 years old!
It is less expensive to buy, run, and operate a new efficient machine!
You will see you water and electric bill reduced!!!!!!!!!
Speed Queen commercial grade top loader uses only 34 gallon of water compared to the others at 54 gallons!
Their front load washer uses, (GET THIS) ONLY 13.9 GALLONS of water and washes in 35 minutes and the clothes are cleaner and last longer cause it uses water agitation instead of a vain to wear out your clothes! How about spinning at 1000 RPM and the clothes come out so dry they are only in the dryer half the time than all the other machines! Thus half the gas or electric bill!!
All my employees have replaced their laundry pairs with Speed Queen!
My Guys call it the, "No Brainer Machine!"
I hope you can utilize the good advice I so enjoy sharing with all the good people we talk to!
http://www.pronto.com/user/search.do?displayQuery=
kenmore%20elite%20oasis%20owners%20manual&SEM=true&query=kenmore
%20elite%20oasis%20owners%20manual&adid=1210312579-6519660d_10_gc&ref=
owners%20manual&creativeid=1167763135&site=
www.fixya.com&loadingComplete=true
ngfam1
Bless You
Please give me a good rating before you sign off here at fixya.com
Sep 10, 2008 | Washing Machines
Washer will not spin
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 46462 Front Load Washer Logo
22 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
