Question about Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E
Dw7000 gen ,willnot run
I can start the gen.with starting fluid but will not cont to run , its as if the choke is stuck and cannot run
    Novelist:
  • 72 Answers
My answer:
Not sure if your Genset is "brand new never used" or not? If it is brand new then all the CHECKS below apply except for #1, as surely the Genset will not run in that case, and will vapor lock as from a vacuum in the gas tank.
Almost 90-95% of all the Genset problems found by the factory approved Genset Service Centers are related to the fact that people don't read the OWNERS MANUAL first, and just didn't put OIL in the Genset (or the right amount) - as they are shipped from the MFR without OIL in the units to begin with!!!!
And here I thought everybody KNEW THAT!!
I guess sometimes you just have to ask the most OBVIOUS ??'s first huh (dumb as " it " may sound)?
If you bought your Genset from other then a Home Depot Store, and it's still under warranty - then you will have to contact that outlet and see what they have to say.
Some other obvious things to CHECK for that may be the cause of a NO start condition even after adding proper gas & oil to the brand new Genset:
1 - Some Genset gas tanks come with a gas cap "blocking insert" under the gas cap that should be removed according to your manual if it states this. (Read manual section on "First Time Starting")
2 - Is the gas tank shutoff valve FULLY OPEN? By the same token (even if the Genset is or isn't brand new) does it have an in-line fuel filter anywhere in the gas line? If not then esp read #5.
3 - Is the RUN SWITCH set to ON or RUN position (this is purely an "Electrical Switch" btw)? Is it working properly? Test it using a known good quality DVM or OHM meter! It's contacts may have become tarnished just from sitting around too long? Esp where you have saltwater conditions in the surrounding air!
4 - Is the choke being set to the proper position with or without using Ether spray to the Carb?
5 - Does the Carb have a Yellow or Black wire coming off of the bottom of the Float Bowl? This goes to the GAS CUT OFF SOLENOID mounted in the Main Jet inside the Float Bowl. NEVER CUT THIS WIRE as some know-nothings have suggested here and elsewhere in postings, as there are better ways to test the solenoid without doing that! If equipped with one - This anti-dieseling solenoid has to work properly or else flooding will occur with the gas shutoff valve OPEN.
6 - VERY IMPORTANT - Is the Float stuck in the CLOSED position not letting gas into the Main Jet? You might try and TAP CAREFULLY on the bottom or side of the Float Bowl with a hard rubber hammer first to try and see if you can dislodge the stuck Float inside. If there is a WIRE at the bottom of the Float Bowl on your model - DO NOT HIT THAT GAS SHUT-OFF SOLENOID WITH THE RUBBER HAMMER - as you WILL damage it! If this dislodges the stuck Float then your problem is solved! NEVER FORCE ANYTHING!! It's possibly that you might have to loosen slightly and/or totally remove the Float Bowl (usually 2 screws) to see if indeed any gas is getting inside to the Float at all. If gas comes out readily but still no gas is getting into the Main Jet and intake then you purely have a DIRTY CARB issue and nothing more! If you're not smelling gas through the air filter box then you are FUEL STARVED. ALSO - Many a brand new shipped Genset will have some kind of NEW gas tank (usually metal gas tanks only) MICRO DEBRIS inside the tank itself or even in the rubber gas line (I've heard of this before, and seen this myself 100's of times with cheaper rubber hoses). That is why an added in-line FUEL FILTER (if your Genset has none) is SO important!! Usually a common $2-3 item at any auto parts store. Once gas is added to the tank all this micro debris is set free to enter into the CARB FLOAT BOWL, and that is where Carb problems will start - even with a "brand new" never run before Genset!!
7 - As dumb as this next ? is to ask I have to ask anyway - Are you getting GOOD spark at the spark plug? Some units ship with the spark wire cap disconnected and it may look like it's on the plug, but in reality it really isn't fully connected! If you are getting a good spark then it's highly unlikely that the Maintenance-free Magnetron® electronic ignition would be bad. Fouled spark plug - YES - bad Maintenance-free Magnetron® electronic ignition - hardly.
8 - If your Genset is used and said to be ? years old, and it just indeed might have some high RUNTIME HOURS on it - it just could very possibly be what sounds like to me (and I personally HAVE SEEN this happen myself firsthand) that the generator brushes are nearly shot - as in almost worn out. They may be getting too too hot - as from excessive current draw at point of contact, and thus the generator sensing circuitry itself is doing an electrical CUTOUT!!
An added protective Genset circuit feature in that the generator itself may indeed be linked to the engine as a type of REV LIMITER or CUTOUT on the Maintenance-free Magnetron® electronic ignition. Again - your operators or service manual should have a pretty good troubleshooting section in it unless you don't have that anymore or never got one if you bought it used to begin with.
If you unscrew & remove the Generator brushes for servicing yourself, and they are indeed below the recommended length (or worse case they are indeed totally worn down) then that most likely is your starting or output problem right there. If you are having Output problems as well.
If you choose to replace the old brushes with new ones yourself - be very careful when seating the new ones - as to their insertion and cap retainer tightening. Never over-tighten those black plastic-like brush retainer screw caps - for if you break one (hard to get immediate replacements is why), or fracture one it could cause the Genset to fail under LOAD, and that very well could do some severe damage to the generator part itself. Take your time doing it, and be patient!!
It has to be one of the CHECK scenarios listed above, as I've covered every possible cause short of a broken wire somewhere - which in that case you will have to schematic trace and DVM or Ohm-meter out wire to wire contacts. This being the least likely scenario from experience.
If you indeed find the Float Bowl assy to be the cause of dirt contamination or varnish build-up clogging the Carb, and you need a walk-through of taking it apart, cleaning it out, and then re-assembling it again - as well as re-adjusting the fuel mixture Adjustment Screws - just give me a shout here, and I'll walk you through it step by step.
That's about all there is unless you got a Defective Genset from the start. Next stop - Home Depot!
Best regards to all with the same problems, and hope I helped you out 100% - all political humor/truth aside.
Please post me a reply as to finding this solution being the best resolve to your Genset problem there by following my recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 08, 2008
00 polaris 90 scrambler wont start first time unless you use starting fluid after that your all right it start fine it has a electric choke?
check the operation of the electric choke as it may not be properly adjusted to be closed at first start
chokes(manual or otherwise) are held open until you open the accelerator/throttle to release the cam lock to allow the choke butterfly to snap closed
the problem will be in the choke area of operation
Feb 08, 2016 | Great Office Equipment & Supplies
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Honda NSR 150 SP. Adjust choke Hi. My bike has been parked for 8 months. The choke cable was stuck n my revs would sit on average at 4000rpm.last time i rode the engine had a knocking sound so i parked...
Yes, don't tamper with it unless you know what to do. Get a pal or local mechanic to give you a run down of what needs doing or can look over your shoulder while you tackle it. You will need access to a good tool kit, some spray oil/wd40 and you should really get a workshop manual because you are likely to need factory info and settings to make it run sweetly. I hope the brake fluid is for a separate problem for which you need experienced help because brakes are your life at stake. Buy a new choke cable.
Jan 05, 2015 | Motorcycles
Engine starts but only runs a few seconds
carburetor sounds like it may be clogged and float is stuck
Apr 24, 2014 | Briggs & Stratton Garden
My 1988 2.3 liter mustang will not start after sitting overnight
Being that this vehicle is a 1988 it is most likely still using an electric choke. When your vehicle is cold (even just not warm enough) it needs a richer fuel/air mixture to start which is what the choke is there for. When you turn the key the choke will automatically shut so the suction from the engine will pull fuel from all circuits of the carb. Anyways.. long story short for some reason it would seem your choke isnt closing as it should. This is generally just a hot wire thats connected to your carb.... maybe a short maybe its stuck open for some reason.. idk but that is where you should focus your attention. Hope this helps.
Dec 27, 2013 | 1988 Ford Mustang
Will not run without manuely chocking
Sounds like the unit has sat, and carb gum, Try draining the carb bowl and re-filling. There is a screw at the base of the bowl. Also make sure when cold choke is closed. And it opens fully after 3 minutes. Check battery voltage on choke coil.
Dec 17, 2013 | Onan 5500 Microquiet Generator
Start up after sitting long time
After sitting a long time
1. drain all gas as alchol in gas absorbs water BAD!!!
2 mix new gas + oil correctly and fill tank
3 spray starting fluid in carb.
4 put full choke
5 set throttle
6 pull till engine pops
7 place choke to half choke and pull a few times to start
8 repeat steps 3 to 8 until running
Other problems are bad gas lines
problem with spark
Bottom line the engine should at least burn off the starting fluid
if it continues to stop the carb is going to be cleaned
Nov 21, 2013 | Garden
Won't run after starting for more than 10 seconds. Have to start with full choke then go to half. won't run at all without some choke.
Most likely your carburator is gummed up. Get a can of starter fluid and a helper. When the engine starts up squirt a little starter fluid into the air intake to keep it running. This will degum the engine and should solve your problem. J.
Sep 14, 2010 | Sport & Outdoor - Others
I have a 2004 yamaha yz250f it will only start with starter fluid
check the carburator if there is a gas goes to it
Aug 30, 2009 | 2004 Yamaha YZ 250 F
Dewalt 7,000 Watt 13 Hp Portable Generator With Electric Start #DG7000E Logo
415 people viewed this question
Top Dewalt Electrical Supplies Experts
JOHN LAPIER
poellot86
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
