Question about Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washer
My gwl11 stops at rinse cycle with last three lights blinking red and beeping. We can take half the clothes out and restart the cycle and it finishes the rinse cycle with no problem ,any suggestions or solutions?
  • emanuelefran Sep 30, 2008
    The washer stops at various places in the cycle. If I shift clothes the least it will continue. Is there an out of balance switch? If so where is it?
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Posted on Sep 07, 2008
SOURCE:
Our miele w911 washing machine keeps stopping in the main wash cycle - red light above the tap symbol. What does it mean?
check that the water flow solenoid is operational and not blocking of the spray rinse requriement
Mar 23, 2015 | Miele Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
F&P GWL11 Washer Stops at rinse - Error Code 37
I hate to say it but it sounds like the controller. I used to have one that had a similar problem that was fixed with a diverter and a controller. Another year or two later it was doing the same thing, so we just replaced it. Just a warning.
Jul 08, 2012 | Fisher and Paykel Washing Machines
The washer will go through the wash cycle, but will not rinse or spin. The machine stops and beeps with the red light at the end blinks while it beeps until i stop it. Please help!!
HI - A RED LIGHT ON ITS OWN MEANS THERE IS A COMM PROBLEM BETWEEN THE DISPLAY & CONTROL MODULES. THE FAULTY UNIT WOULD BE THE DISPLAY, THIS IS A TOUGH ONE BECAUSE THIS DOES NOT ALWAYS WORK, OFTEN THE ACTUAL PROBLEM IS THE CONTROL MODULE ITSELF.
I WOULD BE INCLINED TO REPLACE THE CONTROL MODULE INSTEAD..
CHEERS
Jun 25, 2011 | Fisher and Paykel GWL11 Top Load Washer
Moffat washer light blinking and stops at either full load or stops at rinse cycle
I have the exact same problem on my clothes, washer. Lights blinking, then it stops at the end of the rinse cycle. What the ****. Moffat blows
Dec 20, 2010 | Washing Machines
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
545 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
