Question about Refrigerators
The fridge isnt keepin anything frozen, or wount stay cold.
  • kevinmparry Sep 07, 2008
    fridge just stopped working,internal light comes on but cooling/freezing not working
  • hodder44 Dec 05, 2008
    smeg sra416tp-l
    freezer works but fridge will not get cold
See if there is a yellow stain outside near the burner section. If there is, the weld cracked and you'll have to replace the cooling unit. There may also be the smell of amonia.
Grump
Posted on Sep 07, 2008
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
EVAPORATOR COVER
Manually defrost the evaporator and clean the defrost condensate below each evaporator. If that drain becomes blocked it will cause these problems to happen because when water has nowhere to go the water will freeze on the evaporator. I have seen these symptoms in many Samsung RS2630SH models. Let me know what you find, Thanks Sea Breeze
Nov 15, 2012 | Samsung RS2630SH Side by Side Refrigerator
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our frezzer is working fine but the fridge isnt
the return air ducts are frozen, not allowing cool air up to the fridge
unplug unit overnight and let defrost,you can speed up the defrost time by using a blowdryer in the freezer compartment
Jan 16, 2010 | Samsung Refrigerators
Our fridge isn't staying cold. We have taken off
Sounds like you fan isnt working...its inside the wall..inside take everything out and look for the screws..on the back wall..inside...the fans in there,,unplug and replace..
Sep 20, 2009 | Refrigerators
Compressor runs for 5sec.
your relay and overload on side of compressor is bad.you can replace with original parts or a 3-n-1 hard to start.
Mar 09, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Aman fridge
See http://www.fixya.com/support/t1507330-ice_collects_in_bottom_freezer
also check fan works, is not frozen
Jul 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
High temp red light stays on...
You'll need to tear into it to answer these questions. I suspect the defrost cycle isn't working or the fan is broken. The best way to see what's going on is to take everything out the freezer drawer and remove it. Then take the back panel off the interior rear wall of the freezer section to expose the coils. The coils should have a very even white frost pattern on them (not frozen solid anywhere). If they are frozen up then the air can't flow around them to cool the fridge properly. If the coils seem "normal" with frost only then is the fan just above them working? That fan circulates cold air to both fridge and freezer sections. Let me know what you find out in order to lead you to a repair part.
Jan 12, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
173 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
