Question about Marantz PMD201 Desktop Cassette Voice Recorder
Marantz PMD201 Battery light comes on, unable to record or even play tapes? I have tried unit with different ac cord (that works on all others), and have tried unit with just batteries? What next, do i need to take the unit apart. Thanks.
    Problem Solver:
  • 14 Answers
Adittional info
Posted on Feb 06, 2006
    Problem Solver:
  • 14 Answers
Additional info
    Problem Solver:
  • 14 Answers
Check the outlet voltage and set the AC adaptorfor that voltage fter words, insert the AC adaptor's output plug into the 4.5 V DC jack in the recorder. see attache image
PMD660 Handheld Digital Voice Recorder: I have a Marantz PMD 660 digital audio recorder. T...
This implies that there is not enough current going to the device when running on battery (only back-light but no data) whereas running fine on AC means that the device board is most likely in a good operational condition.
I think maybe once a leaked worn battery which left forgotten inside battery compartment damaged the battery terminals or at least the wires connecting these terminals to the main board, i would recommend you to open and check on that.
Sep 23, 2017 | Marantz PMD660 Digital Voice Recorder
Has error
It's a supply reel fault. I kid you not, the cure is to give it a REASONABLY FORCEFUL open-handed slap on the tape side. it may take a couple of tries but it works about 95% of the time.
Dec 03, 2007 | Sony Handycam CCD-TRV308 Camcorder
How to connect Marantz PMD201 to computer to convert tapes
You have an analog tape recorder, so you need an interface which will allow you to plug it into your computer. This kind of interface is sometimes referred to as a USB Audio Interface. I use a Tapco Link.USB, and it works well, but there are many out there to choose from - you can use something pretty simple, nothing fancy needed.
The interface will plug into your computer via USB cable, and then you will use RCA cables to plug the PMD201 into the interface. When you play the audio on the tape machine, you should be able to select the "USB interface" on your computer as your "input device" and record on the computer. Watch on the computer recording software for input levels (meters that show sound is coming in), and set them to appropriate levels, not too low, not too high (if there is a red zone, you want to flirt with it only on the highest levels) ... don't hit "zero" if your computer shows zero as the peak level for input.
Final Cut Pro is far to complicated for what you are talking about doing. Many computers come with software already installed that will make simple audio recordings like this.
Please feel free to visit my website, rexark.com, for more information on audio and recording, as well as audio presentation and PA systems.
Good Luck!
Mar 04, 2010 | Marantz PMD201 Desktop Cassette Voice...
Marantz CP430 fault
I have had the exact same problem with a CP430, Whether in Play Rewind or Fast Forward, after a short duration the tape stops. After a lot of Looking & thinking, I noticed that a few seconds prior to the tape stopping, the tape counter stops. (If you dismantle this unit be sure to work in an orgainsed fashion,& you will need some tiny Phillips head screwdrivers too) If your not confident then dont proceed.
The tape counter is driven by a belt, & on the spindle that drives the counter is a magnetic wheel, that runs past a sensor on a PCB.
I didn't have a replacement belt, so dismantled the unit, & chemically cleaned the Belt (cellulose thinners), until no more 'black' came off, in order to eliminate the possibility of tape slip, I also used a stiff toothbrush, to clean the plastic gears that drive the counter, as any resistance, will cause the belt to slip. I think the reset button had also been pushed hard, & bent the mechanism slightly, as it had a tight spot, so i adjusted the spindle, & finally lunricated the Counter gears (Not the Spindle & pulley, as its too close to the belt to introduce lubricant). Upon reassembly, The problem seems solved, the unit now plays records Rewinds etc, without any issues.
Its a tiny drive belt, & any resistance in the drive train, (dust / fluff / as tiny grit even) is enough to cause the belt to slip, & stop the counter which in turn stops the tape.
I hope this helps.
Thankyou
Apr 26, 2009 | Audio Players & Recorders
When boss dictates a letter I can barely hear any sound!
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Mar 04, 2009 | Dictaphone 3225 Handheld Cassette Voice...
Stock of Marantz PMD201 Desktop Cassette Voice Recorder
Have you tried here, here or here?
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 22, 2008 | Marantz PMD201 Desktop Cassette Voice...
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Has error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Dec 24, 2006 | Sony Handycam CCD-TRV308 Camcorder
Marantz PMD201
If you are getting a low battery light (that may be the cause of you problem), you should check that the AC outlet settings are right. If the settings are correct, you should take out the AC adapter and try it with batteries (do not forget to disconect the AC from the power and from the recorder!!!). hope this will help. Daniel
Jan 20, 2006 | Marantz PMD201 Desktop Cassette Voice...
Marantz PMD201 Desktop Cassette Voice Recorder Logo
234 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
