Question about SkyGolf SkyCaddie Handheld GPS Unit
Sg4 skycaddie Once I power on my skycaddie and prompted to select start, the skycaddie power's off automatically. Battery is fully charged. I have removed battery and tried to power on again and same results
  • golfan Oct 21, 2008
    My battery is only a few months old. Taking it out and reseating it did not help. When it's plugged in the charge light is red then immediately turns green. The unit will not power on however.
    Problem Solver:
  • 8 Answers
How long have you had this battery for this device? Is it the same battery you have had in the device since date of purchase? Since I don't know the answer to these questions, if the battery is over 12 months old, you need a replacement, quite possibly, even if it is indicating a full battery. The other side of the coin is if it is NOT the battery, it could unfortunately something has gone wrong internally and you may need to send the device in for repair. Try leaving the device's wall charger plugged in and then power the device on and select start to see if the device will then automatically shut off. If it still shuts off, there is an internal problem with the device. If it does not shut off while the charger is plugged in, but shuts off when the charger is NOT plugged in, sounds like a battery issue.
Posted on Sep 27, 2008
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
Tip
Drivers for SkyGolf SkyCaddie SG4 GPS Receiver!
Click Here!! To be forwarded to the SkyGolf website fore more information and your download!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
on May 07, 2010 | SkyGolf SkyCaddie SG4 GPS Receiver
Buttons won't work. Just returned from a 6 day golf trip where the SkyCaddie SG4 worked perfectly for the first 5 days. I recharged it in a wll outlet overnight, then on the next day the buttons...
Power On/Off and Key Lock/Unlock - Press the Power button located at the top right
of the Sky Caddie to power on/off or to lock/unlock the keypad. Upon pressing
the Power button you are prompted to choose either "Off" (Left Soft Key) to power
off the device or "Lock" (Right Soft Key) to lock the keypad. To unlock the keypad,
select 'Unlock" by pressing the Right Soft Key, then choose "Yes".
Jul 02, 2011 | SkyCaddie SG 4 Handheld GPS Receiver
Where can I download the skycaddie installation program for my mac?
I've located the download page for the CaddieSync desktop application for your SkyCaddie SG4 GPS. Simply visit this link: http://www.skygolf.com/skygolf/Membership/Owners.aspx and you should find the download. You'll need to select the Mac option and then choose SG4 for the model. Remember: don't connect your device to the computer until after you have the software installed.
Jun 02, 2011 | SkyGolf SkyCaddie SG4 GPS Receiver
Sky caddie will not sync. error reads your SkyCaddie colud not be found.
plug in your connection cable to the back of the skycaddie with the cord going down towards the battery, not up. This should fix the USB recognition issue.
Jul 26, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Locked on Update screen...will not function at all
Contacted SkyGolf directly and they were very helpful. It was a simple software reset accomplished in two steps:
On the TOOLS pulldown menu, select RELOAD, then select RELOAD LAST APPLICATION, which in my case was the latest firmware update (ver 2.2). They (SkyGolf Tech Support) also accesses your computer remotely via a HS Internet Connection and can do the entire process for you.
It then reset the last update program, which had stalled (causing the lock-up) and then all I had to do was reinstall the latest update, disconnect the Skycaddie and do a GPS RESET outside where it can capture the satellites, then do another SYNC to get it back where it was before the problem began.
I was very thankful that it did not require sending the unit in for repair or replacement.
Additionally, the newest firmware update adds SCORING capabilities to the SG4, which I think is cool.
May 04, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
SG4 Sky Caddy driver
Make sure your cord is plugged into the SkyCaddie with the cord pointing down towards the battery, not going up. It makes sense and it is easier to plug in with the cord going up, but you will eliminate this error if you plug in the cord with the cord going up.
Apr 02, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
SkyCaddie SG4 Direct Connect Problem
Turn your power cable/connection cable over. You are connecting it wrong. When connecting it to the back of the SkyCaddie, make sure the cord it going down towards the battery, not up. That will fix your issue.
Oct 01, 2008 | SkyGolf SkyCaddie SG4 GPS Receiver
SkyGolf SkyCaddie Handheld GPS Unit Logo
290 people viewed this question
Top SkyGolf GPS Experts
Oloyede Monsuru
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
