Question about Kwikset Locks & Locksmithing
Kwikset lock cannot get the key to turn completley to lock whats the problem
  • 38 Answers
Try checking if the lock turns completely with the door open. If it works then the bolt might not be getting past the strike plate on the jamb. Look between the door and the frame when closed and see if the lock is hitting the strike plate. You can also see if pulling in on the door more than normal gets the lock to work. If it does then it is hitting the strike plate. Up north with swelling from the winter and shrinking in the summer it is common to have two sets of holes (one for each season) for the strike plate. Reposition the strike plate in the direction you think it needs. If it does not work properly while the door is open then the bolt is misaligned or you have an internal problem. But more than likely since this is a kwikset it is your strike plate.
Posted on Sep 11, 2008
I am to turn a key 1/4 turn beforekeying the lock. With a key in the lock it will not turn @ all, so a=cannot key my lock.
If you can get access to the inside of the door, the lock can be removed. Be sure you are using the correct key - try all the Kwikset keys you have. If you're completely locked out, you might need to call a locksmith.
Jul 01, 2014 | Kwikset Locks & Locksmithing
Will all kwikset keys unlock all kwikset locks?
I've heard of this problem happening. Whenever the key is changed, check it several times before locking the door. If you have keys duplicated, the duplicates must be very accurate or they might not work reliably. Difficult to know what causes this, unless someone is tampering with the lock, or resetting it improperly. Or could be defective cylinders - which would be disappointing. Pin-tumbler cylinders do not have this problem, it's something unique to Kwikset
Smartkey.
May 21, 2014 | Kwikset Professional Door Lock...
Kwikset SmartKey Error in Changing Key to Lock
Your out of luck this new design is terrible once it locks up and no keys turn it, the lock is done you will have to replace it use the traditional pin tumbler style kwikset and it can be rekeyed unlimited times by a locksmith with or without a key.
Apr 22, 2010 | Kwikset Professional Door Lock...
Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Dec 13, 2009 | Kwikset Locks & Locksmithing
Instructions for programing kwikset lock
-Insert the functioning key (current working key)
-Turn 1/4 turn clockwise
-Insert Programming tool (goes in the real small slot) until you hear the click.
-Remove the Program tool
-Remove the functioning key
-Insert the new key
-Turn back 1/4 turn counter-clockwise.
-The new key should work with the lock now and the old one should not.
Oct 18, 2009 | Kwikset Locks & Locksmithing
Kwikset smart key has no key. need to rekey. how do I do that
Here is the instructions from kwiksets website
http://www.kwikset.com/Files/PDF/SmartSeries/SmartKeyInsEnglishOnly.pdf
Oct 13, 2009 | Kwikset 907 907-L03 Lifetime Polished...
My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Mar 26, 2009 | Kwikset Locks & Locksmithing
Lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Mar 07, 2008 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
181 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
