Question about Poulan "Poulan" Push Mower
Mower won't stay running
My poulan push mower dies after just a few feet of mowing. Sometimes it will restart and others times it will not.
  • scrittenden1 Apr 11, 2009
    My Poulan push mower will start and run based on how many times i prime the bulb. 3 times, runs for 3 seconds and shuts off. 5 times, 5 secs., etc. I have used it 2 times before this and it keeps happening. What should I look for ?
  • Anonymous Mar 23, 2014
    push button starts but dies won't restart until it sits for a while
Assuming it is a B+S engine, if it starts fine and runs rough and smokey as it gets warm and will not get enough speed, the problem is with the Diaphragm between the carb and fuel tank, it costs about £3 and is easy to fit if you have a 10mm and 13mm spanners and a cross heded screwdriver, ver annoying but relatively cheap and simple fix. Max.
Posted on Dec 13, 2008
Assuming you have a fairly clean air filter and a good spark plug, my first guess would be the gas. Make sure it's fresh. Also check the gas tank for dirt and/or water, especially if it hasn't been used for a while, and clean and/or drain the tank if you need to. If you've done all this, maybe the carb. needs adjusting.
Posted on Sep 10, 2008
  • 34 Answers
Water in tank and bowl.....dump ALL GAS from tank and line....then gently loosen bowl screw (1/2 in. small socket) until all gas drains from bowl....gently tighten bowl screw back snugly....put new gas in....give it 2 min. to fill up bowl...prime it 5-6 times ...crank it up....p.s. might need to help it out a little with some starter fluid sprayed into carb. (3 short squirts)
Posted on Apr 27, 2015
Why won't my mower just run already?
Hi, most likely the carby has dirt in it again(if this is what the shop have been cleaning each time). If it comes good when cold the valves need adjusting. Regards Phil.
Jun 13, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
The lawn mower won't stay running. It starts up without a problem. I mowed the lawn for about 45 mins and the mower sounded like it was out of gas. It has plenty of gas in it. If I tilt it, by...
Sounds like the automatic choke to me. When it acts up next time, remove the air filter, and observe the butterfly valve on the carb. Hold it open with a screwdriver, and see if it starts and runs. I have found that wireing the thing wide open solved my Toro problems. The mower is still under factory warrenty however, so you can always take it back! Hope this helps my friend!
Sep 09, 2011 | Toro Power Lawn Mower
I hit rocks with my lawn mower on accident, and now it will run for a few seconds and turn off
This happens often. Sometimes your mower will start and run again and sometimes it won't. When it doesn't run it's because your timing is off, caused by a dented or sheared key.
To replace remove top cover to engine, and any other side attachments, this should expose the flywheel. Remove the top bolt and look between flywheel and top of crankshaft, you will see a small square notch. This is where the shear key is placed. Remove the flywheel and replace the shear key. Replace all parts in reverse order and you should be mowing again. GOOD LUCK.
Aug 31, 2011 | Poulan "Poulan" Push Mower
I have a Poulan push mower that after mowing in a ditch started making a loud noise and running rough. It almost sounded as if metal was hitting metal. The mower was vibrating more than normal. I checked...
If you are sure the oil level is correct then it sounds like it's about to die, unfortunately. A pine cone shouldn't cause any damage, but a large branch may do so. Was it smoking before you shut it down? The vibration could be caused from a bent blade. It could also be caused from a part breaking in the motor. I wish I could have given you better news!
Good Luck,
Jim
Aug 13, 2011 | Poulan "Poulan" Push Mower
I just bought a Poulan PR550N21RH3 Rotary Lawn Mower. The first time I used it it worked fine. While I was mowing the second time I heard a big "POP" then it began to shimmy. What should I do?
check the blade to make sure its on securely and isnt bent or broken.
If something went wrong other than blade damage I would take it back and ask for a replacement.
Jul 30, 2010 | Poulan "Poulan" Push Mower
"Poulan" Push Mower: the mower will start but not stay running...
Have you checked the spark plug to see if it is fouled? If thats not it, maybe the air filter is clogged. If that still isnt the case try some B-12 small engines carb cleaner. Use it generously.
May 17, 2010 | Poulan "Poulan" Push Mower
Mower runs at slow speed only
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
May 13, 2010 | Poulan "Poulan" Push Mower
Carburetor adjustment
it would be a lot easier if you take the cover off the top of lawn mower.
find the carb, it usually sits near gas tank, there should be a screw sticking out of it. tighten until it runs normal. also adjust the air intake/ throttle arm on carb
Jun 24, 2009 | Poulan "Poulan" Push Mower
ROPE ON MOWER WON'T PULL OUT
look under neath and see if anything is stuck in the blade. You probly have a cover for the top part; see if you can pop off a plastic top if you have one.
May 11, 2009 | Garden
Poulan Pro model 185H42ST dies after 30-45 minutes mowing
Put a carb kit in it. If that does not work replace the gas cap they are supposed to breath and if they get clogged it will create a vacuum in the tank starving the engine for fuel.
Apr 24, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan "Poulan" Push Mower Logo
645 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
