We have a Phillips LX800SA surround system which works when playing a dvd, but doesn't work when watching tv - can you help
  • 227 Answers
SOURCE: humming sound when watching tv,but not when watching dvd's
It wounds like you are getting interference from you tv to the receiver. You can try a few different things here.
1. Connect the tv output into another input on you receiver to see if it isnt the channel on the receiver.
2. Try a different set of cables between the tv and receiver. Faulty cables can give you problems.
3. Connect the cable from you tv to a different device. (another dvd vcr blue ray etc.) This will tell you if its the receivers or the tv.
Posted on Sep 13, 2009
  • 47 Answers
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
Posted on Mar 09, 2008
  • 1779 Answers
SOURCE: CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Posted on Apr 04, 2008
  • 20 Answers
SOURCE: surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
Posted on Nov 25, 2008
CLARKPINK55
  • 71 Answers
SOURCE: the surround sytem
bad amp this riddled with faults bad design dont waste your money on this dump it i repaired loads of these this model is bad news and un reliable
Posted on Dec 08, 2008
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
I can't get the surround sound to work while watching tv. The audio works when I play a DVD, but I can't get it to work while watching tv.
make sure the program you're watching is surround encoded, otherwise you will just get L/R or mono audio ;-)
Feb 07, 2011 | RCA Audio Players & Recorders
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
I need help hooking up my tv and dvd player to my surround sound
for your dvd player you just go from audio out on the back of the dvd played to the audio in on the surround sound. and you would do the same for the tv if it has an audio out. your surround sound shoud have more than 1 audio in. and then when you swicht from tv to dvd you might have change the channle, setting, source, or what ever it might be called on the surround sound. and if your tv does not have a audio out contact me at swinginflames@gmail.com and i try to help you. hope that works :)
Feb 22, 2009 | Durabrand 5.1 Surround Sound Computer...
I am tryin to connect my Phillips HTS3011/05 home cinema system to my Technika LCD32-207 tv. It works fine if i watch a dvd, but it doesnt work when i play my Xbox 360 through its HD cable, or watch normal...
My TV has a Output port, It is only output for sound, IF you TV has this, then you need to use those, But i dono if it would have them, If it dosent the you will not be able to use the surround for everything without Plugging it in as you use it,
Nov 25, 2008 | Televison & Video
Surround sound ok whilst playing dvd but not working for tv
Nov 25, 2008 | Audio Players & Recorders
Toshiba TV/VCR/DVD combo MW24F12
You did not say if you have connected the video out on the surround system to the video in on the tv. If not connect it and select that input on the tv.
Aug 27, 2008 | Toshiba SD-V392 DVD Player/VCR
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
No surround sound when watching cable tv programs.
Looks like cable is not sending the full whack of audio data only Stereo. Or if they are then the set top box{is that how it works in the States?] has a fault. Check out the cable co support team.
Jun 02, 2007 | Koss KS3102 System
 Grubhead
Grubhead
