Question about Brother (NC-8000) Network Adapter
Do I have to use there NC-200w connector
Have Home Network have brother MFC7420 can I use a USB wireless Adapter?
Where can I get a wireless LAN adapter for my TV, model number:32D5900?
The WIS9ABGN should work... they're about $170 on amazon.com... the Fenvi n600 should also work. That's only about $50 on amazon - Smart Tv Wireless Adapter for Samsung Tv Instead of Wis09abgn Wis12abgnx - either of those plug into one of the USB ports
You could also use a wireless media adapter like the Linksys WUMC710 - Linksys Wireless AC Universal Media Connector WUMC710 (~$35) - wireless media adapters like that plug into the ethernet port instead of the USB port, and 'look' to the TV just like a hard-wired ethernet connection.
You could also go with a set of Powerline adapters... one connects to the TV's ethernet port, and the other connects to a network switch (e.g. the 4 LAN ports on the typical home router), then they talk to each other at 5GHz to 20GHz through the copper wiring in your home (at those frequencies the signal travels mostly on the outside of the wire, due to "skin effect").
A 'starter set' of those will also cost you about $35.
example - TP LINK TL PA4010KIT AV500 Nano Powerline Adapter Starter Kit up to 500Mbps
Apr 04, 2015 | Computers & Internet
LG Bluray HTS BH6530TW USB wireless adapter
No. There is no processor capable of driving the Bluetooth adapter.
Mar 10, 2014 | Computers & Internet
I need a audio driver for my computer
Download REALTEK PHRE10/100PCI ETH RJ45 100MB nc-r150201 Network Adapter Drivers
  • http://www.free-4all-download.com/REALTEK/REALTEK+PHRE10/100PCI+ETH+RJ45+100MB+nc-r150201+Network+Adapter+download
  • http://www.softitem.com/driver-intel-realtek-phre10-100pci-eth-rj45-100mb-network-adapter-frequently-asked-ques
  • http://www.alldriversfree.com/013/drv/realtek-phre10-100pci-eth-rj45-100mb-nc-r150201-network-adapter
Sep 19, 2011 | Intel REALTEK nc-r150201 Network Adapter
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
Usb adaptor
you might be knowing about it... but check--
Yes you an can but the purpose of the Wireless Usb adapter is to get the wireless connection from the Router to the PC (Computer)
Connect the Wireless USB Adapter to the usb socket of the computer and install the Drivers with the Help of the CD.
Note to get the wireless connection you need the wireless router connect as well in home network
Jan 24, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
What are the steps to hooking up your xbox 360 wireless network adapter
Hello
Plug the wireless USB adapter into the USB port on the back of the Xbox 360 console.
Turn on your Xbox 360 console.
The console will recognize the wireless adapter and will walk you thru the wireless network setup. Be sure to have your WEP key (if encryption is used) for your router before you start this process.
This adapter works well - I am using one and regularly play Modern Warfare 2 with multiple chat sessions. There is no noticable difference between my wired network connection and this wireless network connection.
Happy gaming!
Dec 02, 2009 | Microsoft Wireless Network Adapter Xbox...
Belkin adapter will not connect to home network. It says poor signal strength even when I'm in the same room!
hi it is simple to connect to the wireless network using the belkin adapter.
You can switch over to the windows utility. that should work. it does not work then try to uninstall and reinstall the adapter.
Click here for more info
Oct 11, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
LINUX DRIVER
To know the NIC card use the command
lspci -n
YOu will get then verision and manufacturer of then NIC card then download and instakll then driver for that devic...
the
ifup eth0
or ifconfig
Mar 18, 2009 | Intel REALTEK nc-r150201 Network Adapter
Try to setup home wireless network to share two home computer
Connect the home wireless network router box to the main PC through an ethernet cable with the PC powered off and the home wireless router powered off, then power on the PC & the router. Vista should locate the new wireless network and follow the windows vista network setup procedures. After the wireless network has been detected you then while the second PC's power is shut off you connect dongle adapter to the PC power on and XP will locate the new adapter. You will probably have to enter your networks pin for the connection.
Get back to me when you complete these steps.
Try next time contacting me through an online chat session. We can resolve the issue quicker while chatting together.
Nov 20, 2007 | Hawking Hi-Gain Wireless 802.11g/b...
Brother (NC-8000) Network Adapter Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
